I just installed a ls4 in a project I'm working on. Using the 09 Impala ss e67. I put a ls3 cam and gear in it along with a ls3 timing cover. My question is: the cam position sensor on the ls4 cover is located in a different position ( about 90 - 120 degrees ) then it is in the ls3 cover. Should I not have to adjust the cam timing to make up for this offset? When I try to crank it it just back fired through exhaust. Injectors are pulsing and coils are firing. I changed operating system to a 08 tbss e67 and it fired right up. Nothing else is communicating with ect now and some composted not working but it let me know that it is a issue in the ecm. Gonna flash it back to ls4 is and try to figure out what is going on. Any help would be appreciated
