Results 1 to 2 of 2
Thread: Switch Panel
    Jan 2004
    Default Switch Panel
    Hey guys I just ordered a custom switch panel that I want to use with blackbox logging. I know it will have much more use when v2 comes out, but in the meantime is there a way to wire the cable to a external switch to activate the BB logging?
    No, the connector on the PCB is not designed to have wires plugged into it. Anyway, opening up the unit would be a good way to void the warranty
    Cheers
  1. Going from DSP2 switch to DSP5 switch
    By Dmax15 in forum Duramax LB7
    Last Post: February 23rd, 2010, 03:25 PM
  2. Can Not Display Rr Control Panel...
    By TFZ_Z06 in forum RoadRunner Real-Time PCM Emulator
    Last Post: August 4th, 2008, 05:37 AM
  3. Cant use v2 control panel on pc
    By cLuBsTa in forum FlashScan V2 BB Logging
    Last Post: January 7th, 2008, 05:49 AM
  4. LC-1 F-Body Gauge Panel
    By Beer99C5 in forum Lounge
    Last Post: January 17th, 2007, 04:47 PM
  5. My first EFI Panel w Custom OS toggle
    Last Post: January 14th, 2007, 12:46 PM
