Does anyone have the stock OEM PCM tune? I need to take truck back to stock from the tune that's in it.
Thanks in advance
Mike
Thanks in advance
Mike
Stock tunes are ----> Here
2001 Camaro SS
EFILive Custom OS3
Thanks for the quick response.
Was unable to find mine.
2005 vin 3GNEK12Z95G138406
5.3L
4L60E
PCM FLASH 1MB
OS 12606961 -- OS ID. AP
CAL 12591724 -- BCC YHZT
CAL DEF NAME 1260696.CALZ
VER 7.94 DATE 07 APRIL 2009
3.42 GEAR 4WD
I looked thru the ones that were there to see in any close matches, they had 4.10 gears , 3.73's but nothing close to the 3.42?
Worst case you'll need to take the closest base tune and change the gear ratio/tire sizes. If you want to be BONE stock and can't find a tune, time to break out TIS2Web and flash the PCM with the latest calibration for your VIN.
thanks, went thru it and trying to figure it out. It gets me to almost the end but then doesn't let me download the file needed.
Thoughts?
I have a stock 05 Avalanche 4x4 tune with 3.42 if you want it. Isn't the same OS as yours but you're welcome to it.
Thanks Big Mike!!
