Results 1 to 8 of 8
Thread: Catch can
    Apr 2011
    Default Catch can
    Can some of you give me some advice on a good catch can for my 6.0 boosted engine? I'd like to be able to run both banks into it and I want to stay under $100 and I know there is a lot of them out there in that price range and I know a lot of guys that just run hoses to the ground and call it good but I'd like to stay cleaner and I personally think the vacuum when not in boost of course will help on saving oil. In closing my mind is made up on using one I just want some good advice, maybe some prices or even som linkes would be much appreciated! If like to get on eBay and buy one tonight if possible. SINCERELY, Bryan
    There are various good ones, but they tend to be pricey.
    The good ones have a baffle to seprate oil out from air ( making the air do a sharp turn causes the oil mist to fall out and condense/collect in the bottom ).
    I usually remove the wad of steel wool/mesh, I have fear of it being ingested.
    Apr 2011
    Well I've seen some cheaper ones with baffles and I mean I've used catch cans before but before I buy another one and since the ls's are notorious for the blow by especially with this much boost I just was hoping to get some good advice preferable a link to some favorites
    Dec 2017
    me too
    vented, not vented, check valves, 1 or 2 clean lines? soo much info....
    There's a good thread on this topic at ls1tech.com, let me find it...
    BTW: on ebay I found some $40 cnc-aluminum catchcans that allow you to insert a baffle.
    Dec 2017
    here is my CC/ it is baffled but not very well.
    I removed the breather and sealed it.
    I am guessing here on how to hook it up.
    Driver Rear Valve cover to CC.
    CC to port on bottom passanger side of LSA snoot
    Passanger valve cover to air tube behind the MAF.
    https://photos.app.goo.gl/ASnjS2LjjFUjcDOh1
    https://www.ebay.com/itm/ALUMINUM-OI...72.m2749.l2649
    What is all this info about 2 check valves and 2 clean side ports.
    I really want to keep my LSA clean and engine fresh
    Yes, correct, you want no breather.
  1. Cheap Tech II's, what's the catch?
    By limited cv8r in forum General
    Last Post: July 15th, 2012, 12:05 AM
  2. How to catch when codes are thrown in logging?
    By kwhiteside in forum Gen IV V8 Specific
    Last Post: September 7th, 2009, 07:35 AM
  3. PCV Catch Cans for Sale
    By TAQuickness in forum Lounge
    Last Post: April 11th, 2008, 01:52 AM
