Results 1 to 3 of 3
Thread: Looking for EFIL injector data for Deatsch 65 lb injectors
    Default Looking for EFIL injector data for Deatsch 65 lb injectors
    i still can't believe that injector suppliers ,who's focus is on the aftermarket, still have grasped the concept of supplying the required data for there injectors.
    Customer supplied injectors and I went to there site for info. They have data but when I called and asked for it expressed in the format the aftermarket uses it they drew a blank....
    Any does anyone have these injectors profiled for the EFIL format? 2016 E38
    HT
    www.redline-motorsports.net
    1-954-703-5560
    2006 ZO6 895/866 with APS TT
    2011 HTR-850R Camaro
    Senior Member Behold's Avatar
    Apr 2010
    Did you ever get this?
    Thanks Antony
    Holden Commodore GTS - LS1 5.7
    12 rib Crank Driven Vortech V2 Centri Charger (Intercooled) 9 PSI.
    LS6 Intake
    LS6 Heads
    YT 1.7 Roller Rockers
    BTR Dual Spring with Ti retainers
    BTR Hardend 7.400 Push rods
    Comp Cam JAMCAM
    2 Bar Map
    Mafless
    LS2 Coils
    PCM LS1B with 512KB Running COS5 v01290005
    Senior Member J.Abbott's Avatar
    Aug 2010
    Well I guess you should have called me since my injectors have data!
  1. Replies: 42
    Last Post: June 16th, 2015, 09:30 AM
  2. Replies: 10
    Last Post: September 27th, 2013, 12:25 AM
  3. Converting Ford style injector data to data useful to EFI Live.
    By JOHNBOY in forum General (Petrol, Gas, Ethanol)
    Last Post: May 11th, 2012, 06:19 AM
  4. How does EFIL convert raw data into pids for logging??
    By Redline Motorsports in forum General
    Last Post: October 10th, 2011, 02:21 PM
  5. Injector Offset for #83 lb/hr injectors
    By turbo_bu in forum General (Petrol, Gas, Ethanol)
    Last Post: June 1st, 2009, 04:01 AM
