Results 1 to 8 of 8
Thread: 2012 cummins ecm dead.
    Mar 2016
    Default 2012 cummins ecm dead.
    The ecm had bootloader flash applied with autocal. It went in fine then when i went to put the flash in it went to 100 percent cycled key and now no cummunication. It is a cps5 tune supplied already loaded into the autocal. I own a v2 but sence the tune was in the autocal and licenced i figured use it. I have been tuning class 8 trucks for years alot of cummins but using calt..... not going to finish that one lol. Any time something happens to them just rom boot on the bench. If i had the pen locations for rom booting this ecm i would have already went down that road. When i try to resend any file i get a error saying key is not on.
    It sounds like something with that tune is the issue because if it got to 100% of course that means what flashed in was validated by the ECM is ok but something was obviously messed up and now it is in a reset loop of some sort.
    Is the tuner confident the supplied file was a 100% clean base before converting to CSP5 for you?
    Mar 2016
    This is what i think something happened in the convertion process. This is the second time. The first guy bought the second ecm i got the truck with second ecm with the vin programmed.
    Mar 2016
    how do i pm it won't let me
    You must not have enough posts, just post another 4 messages in here and you should be fine.
    Mar 2016
    ok got ya
    Mar 2016
    if you could pm me your email it still won't let me.
    Nov 2005
    email is ross at efilive dot com.
  1. 2012 cummins tables
    By LMMPerrona in forum Cummins 6.7L
    Last Post: December 10th, 2015, 07:01 AM
  2. wont hook up to 2012 cummins
    By Cwalt50 in forum Diesel
    Last Post: December 6th, 2015, 06:21 AM
  3. 2012 cummins data logging.
    By JT_cummins in forum Diesel
    Last Post: September 22nd, 2015, 04:03 AM
  4. 2012 cummins ecm flash $0549a, key not in ignition
    By jkholder09 in forum Cummins 6.7L
    Last Post: March 15th, 2015, 04:04 PM
  5. 2012 Cummins
    By joelapi in forum Cummins 6.7L
    Last Post: April 12th, 2013, 06:38 AM
