Results 1 to 2 of 2
Thread: RAM 2500 Cummins CM2200 U1601 DTC
    Sep 2016
    Default RAM 2500 Cummins CM2200 U1601 DTC
    Hi all. I wrote tuning file to my CM2200 with speed limiter set to 200 km/h. At the end of flashing error window pops up with message "Error: $0340: Download not Accepted ($40)". DTC U1601 apear, VIN deleted, injector codes deleted, car not starts. After flash original file all parameters sets up OK, car start normally. How to flash tuned file to CM2200? What i do wrong?
    Nov 2005
    The error code description says For Cummins controllers:
    Controller contains security to prevent modified tunes being programmed.
    You'll need to remove the anti tuning boot loader on your ECM before flashing a modified tune. Here is the user guide. http://download.efilive.com/Tutorial...er%20Guide.pdf
    Cheers
    Cindy
    Sent from my iPad using Tapatalk
  1. Replies: 27
    Last Post: May 27th, 2022, 04:18 AM
  2. EFI LIVE for stock 2010 dodge ram 2500
    By DODGE-2010 in forum Cummins 6.7L
    Last Post: September 7th, 2016, 07:39 AM
  3. Replies: 2
    Last Post: July 11th, 2016, 12:38 PM
  4. Cummins U1601 boot mode
    By tkamolz in forum Diesel
    Last Post: May 23rd, 2016, 10:01 AM
  5. Logging Issues freezing at around 2500-3000 RPM Cummins
    By Driveshaft in forum FlashScan V2
    Last Post: May 13th, 2013, 11:08 AM
