Can someone please look at my tune and tell me what I am doing wrong.
Problem is when I tune any truck I always have the Air Density Table error where it will default to 5 then I usually set E5750 to disable. That usually solves my problem. Until now I am trying to tune a 08 6.7 and for some reason it runs like complete crap when that is set to disable. If you turn the high idle on it starts surging and blowing tons of white smoke.
I finally figured out the problem and it is definitely something to do with the E5750 setting.
It has to be the way I set up my tunes because every single 6.7 I have tuned the Air Density defaults to 5 which is what it does when there is an Error.
SO whats the ERROR what am I doing wrong.
Thanks for any feedback this is driving me nuts.
