Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: another tuning question
    Which wideband are you running...?
    It seems to me that your MAF is lagging by about 1 second... post a pic of the MAF duct/plumbing.
    It seems to be getting richer because either of COTP (cat over temp protection mode) is enabling...
    ( PPM has the same commanded fueling but is not enabling since it's MAF/TPS/ECT enablers are not reached )
    Nov 2013
    Yeah,backing up what Joe said above(I hope!) at frame 140 your idling at 1000 rpm with 0% throttle and ~27 degrees timing. At your ECT(194F) your B4603 is commanding 800 rpm. Then at frame 160 idle drops to ~700, timing spikes to ~40 degrees (I imagine from Stall Saver) . For quite a while after that RPM raises all over the place, all without any pedal.
    Nov 2013
    after another glance without playing ten thousand questions in my ear(kids), I see your Stall saver is zeroed out. And even though theres no pedal signal, the vehicle is moving. so either your rolling down a hill in gear, or your pedal isn't properly registering.
    Other things I see as weird: B0108 and 7 are zero'd. I would think these need a proper value in order to use the idle airflow tables. I'm not sure but I think you may be idling based purely on the VE table.
    -Oh, and I'm not a professional tuner, yadada....
    some of the things I see may just be attributed to the 90mm TB and ported intake.
    Do you have the stock tune that this PCM started with...?
    Jul 2005
    hopefully this answers all the questions.
    i do have to get out and do another log for driving, just out for the weekend and trying to install cats next weekend. after my friend helped with the maf scaling, things are better, and i've worked on the idle to get it down lower. i think that was the cause of the high map values.
    log 38 was the last time out driving with the new maf table
    log 41 is the idle where i'm at right now
    Jul 2005
    i have a aem uego wideband
  1. newb tuning question
    By 08z06 in forum Gen IV V8 Specific
    Last Post: May 7th, 2015, 03:55 AM
  2. tuning question
    By 1hotduramax in forum Duramax LB7
    Last Post: September 30th, 2008, 03:34 PM
  3. Tuning Question
    By esco35m in forum General (Petrol, Gas, Ethanol)
    Last Post: October 5th, 2007, 04:18 AM
  4. First Tuning Question
    By nonnieselman in forum General (Petrol, Gas, Ethanol)
    Last Post: May 10th, 2006, 10:58 AM
  5. VE Tuning Question
    By SGCTS-V in forum General (Petrol, Gas, Ethanol)
    Last Post: April 23rd, 2006, 12:31 PM
