Results 21 to 30 of 43
Thread: September 2016: EFILive Beta Test Release
  1. #21
    Is there a limit to how many channels can be polled when working with the e98?
    It seems as soon as you add a 4 channel pid, i have to have almost next to nothing else logged or i get random errors or the logger will just not start or it starts and i get this wonderful pointless error.
    If i drag a pid from top to bottom a pid that wasnt working will start logging. but other pids get no data.
  2. #22
    Investigating...
  3. #23
    Just adding in, it appears you don't need to add any of the 4 channel dma pids for pids not to work.
    Attached is a log, where 2 types of Pedal data would not populate along with engine torque.
    Good old DPF regen going on for a good part of it so noticed EGT1 got to 716'C!E98_T43.pld.efi
    FYI, someone needs to edit the VB backend to allow PLD files now.
  4. #24
    In V7, highlight the PIDs and select Edit->Copy for export to V8, then paste them into V8.
  5. #25
    Lifetime Member bobo's Avatar
    Nov 2005
    Tuned a 6.7 cmc today. I did not notice any changes in the tune file for rpm limit increases over the release I am running on my other laptop. Is this something that will be added in beta?
    2005 Twin Turbo Dmax/Allison Ext. Cab Short Box 4X4
    Best 1/4 11.8 @ 118+ on #2 only
    Twisted Diesel Tuning-The leader in Duramax Tuning Services and soon to offer Common Rail Cummins Tuning!
    Bobotune at rocketmail dot com
  6. #26
    The Cummins CMC (CM2100) was not worked on during this beta phase. Both the CMD (CM2200) and CME (CM2350B) were.
  7. #27
    Any particular reason you want me to do this? I just started V8 scan and added in the supported pids from a fresh. I'll do as requested in an hr when i drive home from work though.
    Would you like for me to get a sample log from 7.5 at the same time? I can happily use 7.5 for now i was using v8 purely to see the additional vane % & desired boost pids.
  8. #28
    Ahh no, sorry. When you posted this:
    I misread that to be "PID files". I was just trying to explain how to copy V7 PID selections into V8 because you can't open *.PID files inV8.
    Now I'm not sure what you meant by PLD files. (Plus what do you mean by "the VB backend"?)
  9. #29
    It was in reference to the VBB forum software. It doesn't allow you to upload v8 log files. due to the new file extension. :-)
    E98-3.pld.efiE98.pld.efie98-v75.efi
    If you look at the v8 log files attached, the torque figures are ridiculous/garbage.
    Slightly off topic, Can i also ask if we can get the additional injection modes added? I think when the car goes into dpf regen mode it's switching to a different injection mode as on my drive home again it went real doughy and i noticed it was no longer running the injection timing i had set. (tested by setting both my mode 1/2 identical)
  10. #30
    Nov 2005
    Are you going to add the rpm limit fix to the CMC (CM2100)?
  1. July 2016: EFILive Beta Test Release
    By Blacky in forum EFILive Beta Software
    Last Post: September 5th, 2016, 03:18 PM
  2. May 2016: EFILive Beta 3 Test Release
    Last Post: June 6th, 2016, 07:30 PM
  3. April 2016: EFILive Beta 2 Test Release
    Last Post: April 30th, 2016, 08:49 AM
  4. April 2016: EFILive Beta Test Release
    Last Post: April 9th, 2016, 03:46 PM
  5. April 2016: EFILive Beta Test Release
