Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: Controller Authorization
    Oct 2006
    Default Controller Authorization
    http://content.efilive.com/documents...horization.pdf
    Will this be automated at some point?
    2006 Trailblazer
    Possibly not, all tuners are in the same boat.
    Hmm this sucks, but it's just another hurdle to overcome to tune.
    I get that the controller sends its Seed when being asked to read, then we can retrieve that and send it off, have a matching Key generated, import the Key, then read as per normal. I'm a little fuzzy on how the Authorization code dealer can generate an Authorization code based on the Seed sent? If they can generate a code, is there a reason the end-consumer cannot? I'm more curious than anything else!
    Yes it does, but it wasn't our choice. But at least you can still program them (for now) unlike the 2017+ T87A TCM, that looks like it is closed off, done and dusted.
    Because it is our own internal system we use that has been trusted to one other person, I know people are probably thinking 'oh just a money grab', no trust me it is not that, we wish we never had to do this too. It has consumed over a month of programming and testing to this point and still requires manual intervention, we too have better things to be doing than workarounds.
    The game has changed somewhat for 2017+, but we just need to accept that, be grateful we can still actually flash these controllers without pulling them apart (eg, Euro tuning) and continue on.
    Aug 2008
    So who is this other person that you trusted?
    Sent from my iPhone using Tapatalk
    Their details are in the document. I won't post it here because spam bots trawl for Email addresses on forums.
    Thanks for the explanation Ross, makes sense to me. And the T87A can't be read (or programmed)?! :( Not good to hear, I'm sure we'll run into issues reprogramming ECMs and the TCM needs to be tweaked as well but it cant be.
    And yes, fortunately we haven't had to resort to pulling them apart (yet).
    Oct 2006
    Will new V8 units, when purchased, still be able to flash 2 controllers, in other words if you bought a V8 unit and go to tune a 2107 that requires the auth-code and seed will it be included in the purchase price, or is additional cost still needed?
    2006 Trailblazer
    It can't be read, programming has a very nasty digital signature system in place. They've gone away from the traditional programming methods to something more like what Bosch do.
    Quote Originally Posted by Chevy366 View Post
    You will still be able to flash two controllers with the one VIN license, no change there. But the auth-code is an additional cost to the licenses, however as I mentioned above the T87A cannot be programmed at this stage so it isn't like you will need two Auth-Codes per vehicle.
    Dec 2005
    Is it known yet or not if the newer Duramax will keep the current T87 or get this new masterpiece from GM ??
    www.mscservices.net
  1. Vortec PCM/Controller not listed under DVT controller selection.
    By Scatfish in forum Vortec V6/V8 Specific
    Last Post: April 5th, 2015, 12:10 PM
  2. What controller to use?
    By Straight 6 in forum Cummins 5.9L
    Last Post: June 25th, 2011, 01:55 AM
  3. Authorization has been set to "Demo" ??
    By 1SlowHoe in forum Tips and tricks
    Last Post: October 14th, 2009, 02:01 PM
  4. Authorization has been set to Demo
    By Aint Skeered in forum General (Petrol, Gas, Ethanol)
    Last Post: January 31st, 2009, 04:57 PM
  5. V2 controller
    By twinki025 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 23rd, 2007, 05:27 PM
