ok I copied the file to user configuration folder, then I did copy and past the 001 -003 data, ( should I manually enter it, or am I doing this whole thing wrong??) and I get the same error when I open either scan or tune tools
No, don't copy/past CLC's 001-3, these are buggy duplicates of what is already there.
These have various syntax errors, can you spot them, I see at least 4...?Code:*CLC-00=00 % -25.0 25.0 .2 "({SAE.LONGFT1}+{SAE.LONGFT2})/2" *CLC-00-002 factor 0.5 1.5 .4 "({SAE.LONGFT1}+{SAE.LONGFT2})/200+1" *CLC-00=003 % 0.0 100.0 .2 "{SAE.MAF.gps}*({GM.DYNAIRTMP_DMA.C}+273.15)*3445.2 /(displacement()*{SAE.RPM}*{SAE.MAP.kPa})*{CALC.LTFTBEN}" VE 0.0 3.0 .4 "{SAE.MAF.gps}*({GM.DYNAIRTMP_DMA.C}+273.15)*15 /({SAE.RPM}*{SAE.MAP.kPa})*{CALC.LTFTBEN}" . . .
And they duplicate stuff that is already in the unedited calc_pids.txt file.
And use g*K/kPa rather than %.
that works so I'll see what happens tonight on the way home, 50 miles 1 way, all but 4 miles on 4 lane, I should be able to get some good data
Like this??
*CLC-00-001
g*K/kPa -25.0 25.0 .2 "({SAE.LONGFT1}+{SAE.LONGFT2})/2"
well It didn't like that
I don't know about this stuff?? now I can't set up my CALC.VE_TABLE??
Your CALC.VE_TABLE is the same (actually it's worse) as CALC.VET.
