Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: Unlocking autocal
  1. #21
    Lifetime Member DURAtotheMAX's Avatar
    Nov 2005
    The VIN is not updated in the ECM as part of the reflash process.
    Except technically on LB7 and LS1, where the VIN is part of the main flash, and subsequently gets erased/re-written during a full-flash...no?
    Ben
    2005 Silverado, CC/SB, 4x4, LT, LILLY/Allison
    12.9s @ 108 mph
    many thanks to Ross and Paul
  2. #22
    Dec 2005
    Ahh no.
    I flashed LB7 ecms quite a lot, the VIN is never changed unless the ECM gets hosed up on the FULL FLASH.
    Not sure on LS1
    www.mscservices.net
  3. #23
    Dec 2005
    Not without the consent of the original tuner.
    I have a question regarding consent, if the tuner is not in business anymore, makes no difference why, and customers now have a device they cannot use, or if they have a tuner refusing to unlink a device, is that it. ???
    Oh well, sorry about your luck, gotta buy a new device ??
    I know EFI-Live has no control over the tuner, the policy, etc.
    But if the company is out of business it kinda sucks for the customer.
    I understand it from both sides, as someone who sells autocals and has had customers contact me that their "TUNER" is being difficult or has refused to help them anymore and or is just being difficult with getting updates sent, and they want a switch to someone else and cannot get any support for the device getting unlinked.
    Just wondering if that is it ?? As in they are SOL !
    www.mscservices.net
  4. #24
    Quote Originally Posted by DURAtotheMAX View Post
    Ben
    No. For LS1 and LB7, during a full flash EFILive saves the NVRAM area prior to erasing it, and during the reflash it writes the saved NVRAM area back to the flash. The VIN and other important info is stored in the NVRAM area and should be retained as far as is possible. Obviously if a full-flash crashes after erasing the NVRAM and before re-writing it it can cause the NVRAM to not be restored correctly.
  5. #25
    Quote Originally Posted by GMC-2002-Dmax View Post
    The "contract" of an AutoCal sale is between the tuner and his customer we can't interfere with that. EFILive sells AutoCals to tuners with the contractual obligation that it is (will be) linked to that tuner's FlashScan and that tuner then controls that AutoCal. We won't unlink an AutoCal without the tuner's consent. If the tuner is out of business and/or the tuner no longer has his FlashScan and physically can't unlink the AutoCals, BUT the tuner is OK with the AutoCals being unlinked then EFILive may unlink them. However, EFILive will not do that unless EFILive receives written authorization* from the registered owner of the FlashScan device to which the AutoCal is linked.
    * written authorization includes an email from the same email address under which FlashScan was registered.
  6. #26
    Dec 2005
    I understand that hands get tied, it's too bad, but it is how it is.
    www.mscservices.net
  7. #27
    Nov 2005
    Ahh no.
    Not sure on LS1
    Right, thats what I was referring to.
    The LB7 and LS1 are different than the newer controllers as far as where/how the VIN/serial number are stored.
    12.9s @ 108 mph
  8. #28
    Lifetime Member IdahoRob's Avatar
    Apr 2006
    Does the remote link/unlink code work for all the autocals the tuner has sent out with the same V2 license, or does a new code need to be generated for each individual autocal on a case by case basis?
    Thank you,
    2013 LML, 550hp with factory emissions, stock cp4 and compound turbos.
    2002 LBZ, 4x4 (Max'd Out) 6000lbs 9.36 @ 154 mph NHRDA Champion and Record holder
    1965 El Camino, duramax 9.6 @ 149MPH
    All EFI tuned by Adrenaline Truck Performance
  9. #29
    Nov 2005
    The link/unlink codes are unique to the device pairs.
    With FlashScan connected if you were to generate link/unlink codes for 5 different Autocals each code would be different.
    With a different FlashScan connected, if you generated link/unlink codes for those same 5 Autocals each code would be different to the codes previously generated.
    Taking one of those AutoCals aside, the 2 link codes per AutoCal could link the device if it was not already linked, and the 2 unlink codes could unlink the device, but which code would be valid at any particular time would be dependent on the FlashScan that provided the link. Those codes can be reused for that unique AutoCal/FlashScan pair.
    If your customer had your link and unlink codes, and the link/unlink codes of another tuner he then has the tools to switch between the 2 sets of tunes at any time.
    Cheers
    Cindy
    Sent from my iPad using Tapatalk
  1. Converter unlocking at 80 mph
    By Cool28 in forum Gen III V8 Specific
    Last Post: April 13th, 2012, 11:25 AM
  2. Unlocking pcm
    By carter01 in forum Gen III V8 Specific
    Last Post: May 23rd, 2011, 12:36 PM
  3. unlocking a locked PCM
    By rubbersidedown in forum Gen III V8 Specific
    Last Post: August 12th, 2010, 11:47 AM
  4. Unlocking PCM
    By mjp80538 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 16th, 2006, 02:56 PM
  5. Pcm Unlocking
    By JCA in forum Tips and tricks
    Last Post: October 19th, 2006, 03:22 AM
