Results 1 to 10 of 12
Thread: BBL 2010 Camaro
    Feb 2015
    Default BBL 2010 Camaro
    Been trying to figure out how to configure it using v8 scan and tune. I think I have the e38 pids loaded on now. Only problem is my wb02 and other custom calc pids I use in v7.5 don't show up and I can't find them under anything for the v.8 scan and tune. Do I need to somehow re-create these pids for v.8 aswell?
    Which wideband do you have...?
    Post a V7 log file.
    Feb 2015
    Ballanger Motorsports afr 500. The new remake of the NGK afx. I'll post a log at some time today. Do you want the calc pids I have to for v7?
    Feb 2015
    Default log and calc pids
    Sorry car got put into storage. Here is a log of another Camaro (2013 LS3) Im working on, I would like to use bbl, just got a 16gb sd card, I have dtc definitions loaded. I only really use the v7 scanning. I have a custom calc pids made for the wideband (BALLANGER MOTORSPORTS AFR500). I cannot figure out why the wideband ben will not work. That SAE.LAMBDA pid does work in this car just fine. Also I can view lambda via the wideband in the scan tool, But the ben factor does not work (actual/commanded). Heres what Im working with
    Add two blank lines at the end of your calc_pids.txt.
    from looking at your calc_pids.txt, you have to log SAE.LAMBDA and EXT.AD1 and EXT.AD2.
    You have some interesting idle oscillations going on...
    Feb 2015
    Indeed I do. But I have it better now. Trying to play with proportional and integral tables. Owner doesnt want to drill a hole and neither do i. Proportional has to be tamed alot and integral has to be linear. What about black box logging to eliminate my laptop for longer logs and get better averages.
    In the V2 section of the forum there is a thread o how to setup V2 from scratch (I'll post a url to it when I get to a PC).
    ~Moderator~
    Feb 2015
    I guess the question I have is I need to use these custom calc pids. In the scan and tune I could not figure out a way to use them being it's under the v7
    Calc pids are not actively logged, they are after-computed when viewing the log in V7/V8 scantools... so they don't show up on the V2 LCD during logging.
  1. 2010 Camaro
    By etmotorsports in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: April 13th, 2011, 07:22 AM
  2. 2010 Camaro
    By etmotorsports in forum E37, E38 & E67 PFI ECM's
    Last Post: December 21st, 2010, 07:50 PM
  3. 2010 Camaro L99 vs a 2011 Camaro L99 Tune.
    By BowlingSS in forum E37, E38 & E67 PFI ECM's
    Last Post: December 6th, 2010, 10:33 AM
  4. 2010 Camaro
    By wayneosan in forum General
    Last Post: October 19th, 2010, 01:24 AM
  5. 2010 Camaro
    By jnjprfrmnc in forum E37, E38 & E67 PFI ECM's
    Last Post: October 29th, 2009, 08:06 AM
