So I have been working on my autove tune with lc-1 and I just don't understand exactly it is supposed to work. We are supposed to be putting the ECU in OLSD and when we do we run off of B3506 and I get that but what I don't understand is that above 60kPa we start changing the commanded ratio which means the LC-1 that is calculating the BEN for 14.62 is now being fed bad data from the ECU. If you log commanded air fuel ratio (GM.AFR) you can see it moves around when it should be steady. Any input?
I have attached my tune files with corresponding log files.
