Results 1 to 7 of 7
Thread: 2011 6.7 delete problems, non US customer
    Nov 2014
    Question 2011 6.7 delete problems, non US customer
    Hi, guys.
    I'm non US based and well aware of EFI live policy for allowing deletes for non US diesel trucks. Actually I deleted a couple of LMMs with no problems.
    Customer asked to delete 2011 Ram 6.7
    So I ordered a Cummins upgrade, then things became a little strange.
    Questions are as follows.
    1. Can't pull stock file from the truck.
    ECM type detects ok, but shows red cross and throws error message when i try to read it. Is it normal (like LML Dmaxes) or not?
    2. Is it possible to turn off eco stuff with EFI live like Duramaxes? Or are there different approach for Cumminses for some reason?
    Can't see any EGR or DPF options in stock 2011 Ram 2500 6.7 files downloaded from the web, can't find any non-US 2011 files either.
    It would be great if somebody from EFI live crew would clear things a bit.
    Sole reason for ordering Cummins upgrade was deleting newer Cumminses, I have "other" tuner too and can do things with 5.9s without additional expenses. Right now I wonder if $450 were basically thrown away.
    '04 Silverado 2500HD CCLB LB7/A5
    '03 GMC Topkick C5500 LB7/A5
    '10 Dodge Ram 2500 CCSB 6.7/68RFE
    Lifetime Member Road's Avatar
    Feb 2015
    You will no be able to change any emissions parameters with EFI. The parameter's you have is all there is.
    Nov 2014
    Quote Originally Posted by Road View Post
    Got it. Thought Cumminses were no different from export Dmaxes in this aspect. Think I'll stick with Chevys.
    Senior Member KhakiCummins's Avatar
    Sep 2011
    Quote Originally Posted by Vlad0380 View Post
    EFI Support for the 2010+ Cummins is the same as it is for the 2011+ Duramax with respect to emission parameters.
    Duane
    2008 Ram 3500 QuadCab
    Hamilton 110# Springs & HD Pushrods, ARP 2000s, EFILive, SB 3250 DD
    Nov 2005
    There are no emissions parameters for 2010+ Cummins. The Cummins Quick Start explains that the read is blocked, how to find a matching base file, how to manage the heightened security on the ECM (you won't be able to flash modified tunes until you remove the RSA security) and that for decent logging you'll need to upgrade to CSP given the factory offering is so lacking.
    Cindy
    Sent from my iPad using Tapatalk
    Nov 2014
    Thanks to all for explanations.
    Cindy
    Cummins quick start here https://forum.efilive.com/showthread...ns-User-Guides doesn't open, other guides open ok. Could somebody from EFI team look into that? Thanks.
    Aug 2014
    Download the guides right from the website.
    https://www.efilive.com/documentation-tutorials
  1. 2011 lml OS6249 delete issues
    By LMMPerrona in forum Duramax 2011+ LML / LGH
    Last Post: July 29th, 2021, 09:12 AM
  2. 2011 5500 problems
    By Bad-Duvall in forum Cummins 6.7L
    Last Post: April 8th, 2015, 07:29 AM
  3. 2006 Lbz egr delete problems p0405,p0098
    By JCM1107 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 12th, 2014, 02:26 AM
  4. Code Delete Problems
    By chrleb2 in forum Cummins 5.9L
    Last Post: May 8th, 2014, 01:09 PM
