Results 1 to 2 of 2
Thread: calc pid no longer works???
    Oct 2003
    Default calc pid no longer works???
    I have a Tech Edge WBO2 that is wired into the left rear O2 harness. I hacked it to have a 0-1 volt output and made a calc pid to convert that to AFR. It worked until I upgraded to 7.3 and now, although I can select it in the pid screen, I can't find it on the dashboard screen. What has changed? What do I have to change to make it work again?
    Obviously, I can undo my hack and feed the TE WBO2 in via the A/D in the EFilive hardware, but I shouldn't have to.
    What are the equations for the builtin WBO2 calcs? I scanned all the files and didn't find anything.
    The equations are in the file:
    \Program Files\EFILive\V7\Configuration\sae_generic.txt
    Search for the text: Tech Edge
    Installing the latest software may overwrite/reset your dashboard files - you may need to add your AFR gauge back onto the dashboard.
    Right click on the dash and select Add->Gauge->theme->gauge name. Where theme is the folder in which you saved your AFR gauge, and gauge name is the gauge's filename.
    To resize/reposition your AFR gauge, right click on the dashboard and uncheck the option: Dash settings->Lock dashboard (or use Ctrl+Alt+L hotkey). Then left click on the gauge and it will show a white border. Drag and resize the gauge with the mouse. Then re-lock the dashboard to prevent accidental alterations.
    Make sure the PIDs: {EXT.AD1} and {EXT.AD2} are selected and that your Tech Edge wideband PID(s) are also selected and returning valid data. Regardless of what is displayed on the dashboard, the [Data (F9)] tab page will display the selected PIDs and their values.
  1. I can no longer log data
    By Jasondt2001 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 12th, 2009, 12:09 PM
  2. Longer delays with BBL & other changes
    By Kevin Doe in forum FlashScan V2 BB Logging
    Last Post: September 25th, 2008, 09:02 AM
  3. no longer a cam virgin :)
    By The Alchemist in forum Gen III V8 Specific
    Last Post: June 11th, 2007, 11:38 AM
  4. Engine won't run longer than 1 sec
    By thetallengineer in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 28th, 2007, 12:57 AM
  5. Replies: 4
    Last Post: August 3rd, 2006, 10:36 AM
