Results 1 to 7 of 7
Thread: Unable to Open any E78 ctz file
    Feb 2008
    Default Unable to Open any E78 ctz file
    chase 2014e78 stock ecm.ctz
    I've done the latest V7.5, V8, and firmware updates. I can read/write the e78 ECM all day long. I'm just unable to do anything with any e78 ctz files in V7.5 (180), as I get a warning message related to GM Cal reflashed, COS loading without initial ctz file, or attempting to load a COS.
    If I open in 7.5 there are no parameters to inspect and only the VIN decoder/history/display box is able to scroll through tabs.
    Any suggestions? LS1A/B, E38, E40 ecm's all work without issue.
    LQ4, Pro-Flo, heads, Stock48 cam'd, twin TO4E 2001 C5 830rwhp/905rwtq
    2001 GMC RCSB pt88/5.3/4l80e/14 bolt 11.34@123.2 best pass so far with a 1,82 60' @ 13lbs boost
    Can you please post up one of the tunes are having issues with?
    Feb 2008
    Here is one file from today, above in original post. I've also tried opening up attached e78 files posted on the forum with th same end result.
    Quote Originally Posted by joeygc5 View Post
    No attachment...?
    Nov 2005
    The file you have attached is an operating system that is not yet supported.
    When you open the file in V7, the below warning message is displayed to alert you that it's an Unrecognized PCM
    The good news is, that OS has been mapped for support and is about to be sent to beta testers for validation. The time frame for public release is unknown, that will depend on feedback.
    Cheers
    Cindy
    Feb 2008
    Quote Originally Posted by cindy@efilive View Post
    Cheers
    Cindy
    Thank you, and I understand this is yet to be released in Beta as I replied to the other e78 thread which talks about the truck ecm Beta release. However, I get this pop-up message even if trying to open Cruise or other supported e78 ctz files posted to the forum.
    Nov 2005
    I'm not sure which E78 files you tried to open. A number of users have posted unsupported files to our forum. The below is a list of supported operating systems that will open with the latest public release software.
    Cheers
    Cindy
  1. Anyone have a 2wd E78 file I can try???
    By rubbersidedown in forum E78, E83, E84 PFI ECM's
    Last Post: July 15th, 2014, 12:49 AM
  2. Unsupported E78 file
    By wesam in forum E78, E83, E84 PFI ECM's
    Last Post: March 23rd, 2014, 08:30 PM
  3. E39A ctz file for Opel Insignia
    By madia in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: July 31st, 2013, 07:40 PM
  4. cannot open file
    By 1hotduramax in forum General (Diesel)
    Last Post: September 17th, 2008, 01:46 PM
