Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: 2012 Cruze E78 Rev Limiter Question
    Oct 2009
    Default 2012 Cruze E78 Rev Limiter Question
    I'm running a 2012 Chevy Cruze 1.4 turbocharged EcoTech in a sand rail. I'm using an E78 controller with the 2012 OEM calibration. Operating system number 12646746. I can't get the engine to rev past the hidden 4000 rpm rev limiter. The system is code free no reduced power mode is indicated. however at 4000 Rpm the throttle closes to 30% and will not allow anything above that Rpm. Has anyone run up against this and if so can you tell me what I am missing. Do I need to start with a different base calibration that uses a different operating system? Any advise or help would be greatly appreciated.
    STEVE SBELGIO ECLIPSE ENGINEERING
    Nov 2007
    Post your tune file. What transmission?
    Oct 2009
    The calibration is for a six speed manual transmission, the sand rail uses a volkswagen trans axle. I am not currently supplying any speed signal to the controller
    Jan 2007
    I'm guessing you're using an auto calibration. There's a transmission default torque table that is used if communication with transmission controller is lost. It's usually set to negative torque numbers above 4k rpm. I don't think efilive has it available to edit. Swapping to a manual cal should fix, and would solve idle issues you'll have if trying to use an auto cal.
    Oct 2009
    No i am using a 6 speed manual transmission base calibration
    Jan 2007
    Quote Originally Posted by SBELGIO View Post
    Possibly the lack of speed input and clutch position is causing it to default to that table. Seems the manual cal would work. You could try to get efilive to add the table, hptuners has it. It's not an issue for anyone but us motor swapping folks.
    Oct 2009
    I contacted hp tuners and they said that they did not support this operating system, perhaps i need to contact them again. I attempted to simulate the clutch pedal input however i can not get the controller to recognize the input
    Jan 2007
    You'll need one of the 0-5v sensors to make the clutch input work, but its not really needed if you can modify this table. There's a lot more parameters that pertain to standalone engine use in the other guys software, I'm pretty sure your cal is now supported. I have an e39 LEA 2.4l running standalone with an auto cal behind a t56, so I've figured out all the tricks the hard way...
    Oct 2009
    I am using a 0-5 volt reference ; as for the support as of yesterday they said no on this operating system
  1. HELP 2012 1.4L turbo Cruze tune
    By bstuder11 in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: January 19th, 2014, 12:05 AM
  2. Speed limiter setting on E78 PCM - Chevrolet Silverado 2500 HD 2011
    By Treurentner in forum E78, E83, E84 PFI ECM's
    Last Post: October 9th, 2012, 12:46 PM
  3. Rev limiter help
    By charcold-bowtie in forum Gen III V8 Specific
    Last Post: May 28th, 2009, 02:51 AM
  4. Rev limiter help
    By Badmire68 in forum Gen III V8 Specific
    Last Post: January 17th, 2008, 09:53 AM
  5. 97 C5 Rev Limiter ?
    By Kool C5 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 11th, 2007, 11:28 AM
