Results 1 to 10 of 14
Thread: E78 BiDirectional Controls DVT
    Dec 2013
    Default E78 BiDirectional Controls DVT
    Is there any chance of getting some bidirectional controls available for the e78 controller.
    Using the other controller selections only allows for use of setting a desired idle speed and forcing open/closed loop.
    I was hoping for injector disable at the very least.
    If you choose E38 all that should work on the E78 as well, which controller have you been selecting?
    Feb 2006
    does this also apply to the e83b or entirely different?
    Should apply to that too, GM got pretty good on......wait for it.....standardising! between ECM's as the years have progressed.
    Dec 2013
    Anytime I try to enable the control for the injectors, it says that there was a timeout and it won't allow me to disable individual injectors. It was even picky about enabling closed loop if I hadn't enabled the fuel trim learn first.
    The above was tried on the E38 but I also tried all of the ECMs that were L4 or looked very similar to the exterior of my ECM
    Unfortunately we don't have a car with an E78 to test this on anymore, we'll have to ask around to see what others find. But timing out sounds like a communication issue, still E38 should have worked.
    I can test DVTs on my Sonic if you need someone, shoot me a PM.
    Nov 2005
    That would be awesome Eric. If you could test, then run trace files as per the Software a build beta requirements and submit those in the beta section Ross and Paul can follow up. Please make sure you upgrade to yesterday's release first.
    Cheers
    Cindy
    Lifetime Member Boost's Avatar
    Dec 2006
    Hey, I caught this one just in time! I also have a daily E78 if there is anything I can help with.
    8.7 @ 84 (1/8 mile) bolt-ons
    Dec 2013
    I'm also good to help with this as well.
  1. 4L60E wont lockup using bidirectional controls
    By Antwon in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 19th, 2014, 10:38 AM
  2. Replies: 8
    Last Post: May 16th, 2007, 10:04 AM
  3. Bidirectional controls and spark....
    By Redline Motorsports in forum General
    Last Post: June 12th, 2006, 02:35 PM
  4. Bidirectional Controls and V7
    By bink in forum General (Petrol, Gas, Ethanol)
    Last Post: October 8th, 2005, 04:53 PM
