I have a 08 Duramax with a P0642 code. I was wondering if it's possible for me to monitor sensor reference A voltage with my flash scan V2.
Is it possible? If so what's the PID?
Thank you!
Sent from my iPhone using Tapatalk
Thank you!
No I'm not aware of any way to do so.
That 5V circuit connects to the APP 1 Sensor, EGR valve sensor, Fuel Rail Pressure sensor and Oil Pressure sensor.
You Need to unplug each 3 wire sensor ONE AT A TIME , then see if your 5V line comes back steady when the ignition is switched on (don't try to start).
2006 Ram 2500 4x4, 5.9 CTD, Laramie, QC
Fully Built 48RE, Billet Flex Plate, Triple Disc TC, 62/65 HE351cw
2017 Corvette 3LZ Z06 M7 with Z07 Package
