Results 1 to 6 of 6
Thread: When to get bigger injectors
    Oct 2016
    Default When to get bigger injectors
    Hey folks, I have a 2009 CTS-V, kooks headers and x pipe, high flow cats, 2.55 pulley, still stock injectors.
    I was told they'd hold but we are dipping into colder weather here and I'd rather be safe than sorry. On my latest log the IDC said 127. And I believe pulse width went up to 26 at one point I don't think that's good.
    What size injectors should inbe looking for, a cam and nitrous are my next power mods.
    Also after installing the injectors exactly what all do I calibrate ? Thanks in advance I'm very new to all this it's a lot to learn.
    Anytime IDC exceeds 100% the injectors can't supply the fuel that the ECM is requesting...
    at 127% you are dangerously lean;
    for safety, injectors should be big enough to keep IDC below say 80-90%.
    Oct 2016
    Is the IFR the only thing I calibrate? After install
    No... you also need the injector characteristics data for the other injector tables.
    Oct 2016
    I'm assuming all that's sent to me when I purchase them, (sorry so many questions) do we have a tutorial I can read through?
    Aug 2013
    Quote Originally Posted by BADCADDY View Post
    ID gives you data with their injectors... but they are seriously expensive injectors.
    Good luck trying to get injector data from any other injector seller.
  1. tunning for bigger injectors
    By gigabrock in forum Duramax LB7
    Last Post: February 18th, 2015, 04:06 PM
  2. Bigger injectors?
    By Scarface in forum Duramax LLY
    Last Post: November 20th, 2014, 04:50 AM
  3. Bigger injectors
    By 06megatuned in forum Cummins 5.9L
    Last Post: June 23rd, 2014, 12:09 AM
  4. Do I need bigger injectors or more beer!!!???
    By ssvolvo in forum General (Petrol, Gas, Ethanol)
    Last Post: September 11th, 2008, 11:36 AM
  5. Tuning Bigger Injectors Help
    By BrianC98Z28 in forum Gen III V8 Specific
    Last Post: February 10th, 2008, 04:40 AM
