Results 1 to 3 of 3
Thread: using CTS2 with GDP
    Oct 2016
    Default using CTS2 with GDP
    How do I switch the DSP parameters from Hard Wire to Serial?
    Sep 2017
    I have the same question. when I do switch them do I need to re-flash the truck to make it work. I'm new to this and trying to get it figured out is frustrating. if someone could walk me through what to do it would be greatly appreciated
    Jan 2009
    The switch is done in the tune, which means whoever sent you the tune would have to set it that way and then flash the truck with it.
  1. csp 5 pass thru switch W/ cts2 monitor
    By ogden08 in forum Cummins 5.9L
    Last Post: August 10th, 2015, 11:01 AM
