Results 1 to 5 of 5
Thread: JTAG Files
    Lifetime Member Road's Avatar
    Feb 2015
    Default JTAG Files
    I imported a JTAG file into v8 today and then went straight to 7.5 with the file and saved the file then reopened the file to flash it and it was a different OS than what I imported. So imported it again and saved the file with V8 and it saved it correctly. Now I know to save the file with V8 but don't understand why or how 7.5 could save the file as different OS all segments had different numbers and if you tried the flash the file I got incorrect OS error and it was the file I read from the ecm. Is this normal?
    Kind of doesn't make much sense actually , I haven't heard of it as an issue with the JTAG import option.
    Feb 2015
    Yea should have duplicated it before posting. It works fine. Don't know what I was doing....
    Feb 2015
    Duplicated it a couple of times. It's no big issue. If I import with the tool in V8 and open the file without saving it then 7.5 will load the last file it opened instead of the imported file.
    Sorry Mike, I just can't picture how this is possible, maybe I am not understanding your process.
  1. E78 benchtop power and jtag pins?
    By jonr in forum E78, E83, E84 PFI ECM's
    Last Post: April 23rd, 2012, 03:27 PM
  2. E78 benchtop power and jtag pins?
    By jonr in forum E39, E80, E82 & E92 SIDI ECM's
  3. Direct (BDM / JTAG) Datalogging?
    By N0DIH in forum RoadRunner Real-Time PCM Emulator
    Last Post: April 28th, 2010, 04:01 PM
  4. Where did all my files go?
    By Ira in forum FlashScan V2 BB Logging
    Last Post: December 5th, 2007, 04:24 PM
  5. OS files
    By DaddySS in forum Custom Operating Systems
    Last Post: January 23rd, 2007, 01:27 PM
