Results 1 to 10 of 14
Thread: Fast idle good by REALLY lean - NOT VVE
    Senior Member Behold's Avatar
    Apr 2010
    Default Fast idle good by REALLY lean - NOT VVE
    Helping someone tune there VE GTS with an E38
    When revved to about 2k in neutral the AFR goes to about 16-17 sometimes higher. But in gear under load in the same area on the VVE it's super rich. As we lean it out the fast idle gets leaner. This is almost like there is some correction table.
    What might it be? It's stumping me.
    Thanks.
    Thanks Antony
    Holden Commodore GTS - LS1 5.7
    12 rib Crank Driven Vortech V2 Centri Charger (Intercooled) 9 PSI.
    LS6 Intake
    LS6 Heads
    YT 1.7 Roller Rockers
    BTR Dual Spring with Ti retainers
    BTR Hardend 7.400 Push rods
    Comp Cam JAMCAM
    2 Bar Map
    Mafless
    LS2 Coils
    PCM LS1B with 512KB Running COS5 v01290005
    Post log/tune files.
    Apr 2010
    As requested.
    The VVE is more updated now but understanding why its so lean only not under load would be great.
    CY09 - VVE TUNE - OL - BOUND2SMOOTH - NEWPCM - MFSCALE V1.5.ctz
    OLdrive0019.efi
    OLfastidle0020.efi
    Thanks Antony
    LS6 Intake
    LS6 Heads
    Comp Cam JAMCAM
    2 Bar Map
    Mafless
    LS2 Coils
    Quote Originally Posted by Behold View Post
    Thanks.
    Are you running VE-only or VE/MAF...?
    Apr 2010
    VE only. SD Closed loop longer term but tune is in SD OL mode for VVE tuning.
    Thanks Antony
    LS6 Intake
    LS6 Heads
    Comp Cam JAMCAM
    2 Bar Map
    Mafless
    LS2 Coils
    Apr 2010
    Joe did you notice anything?
    I assume an idle correction is causing some leaning out. but surely fast idle would be outside the idle table?
    Thanks Antony
    LS6 Intake
    LS6 Heads
    Comp Cam JAMCAM
    2 Bar Map
    Mafless
    LS2 Coils
    Are you seeing an immediate MAF DTC...?
    Try setting B8003 to all zeros.
    Aug 2013
    Reset the fuel trims.
    Apr 2010
    Done. No real difference.
    Thanks Antony
    LS6 Intake
    LS6 Heads
    Comp Cam JAMCAM
    2 Bar Map
    Mafless
    LS2 Coils
  1. Fast Idle
    By LIL DAVE in forum General (Diesel)
    Last Post: January 8th, 2013, 07:53 PM
  2. can a lean idle or going lean during light cruise harm the engine?
    By ryans1000 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 3rd, 2009, 01:44 PM
  3. Efi live and factory fast idle
    By maxxflip in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 17th, 2009, 02:50 PM
  4. what table controls how fast it drops to idle when slowing down?
    By mvvette97 in forum Gen III V8 Specific
    Last Post: September 8th, 2009, 09:18 PM
  5. Good VE numbers except at idle?
    Last Post: June 3rd, 2007, 12:39 PM
