Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Fast idle good by REALLY lean - NOT VVE
  1. #11
    Senior Member Behold's Avatar
    Apr 2010
    Quote Originally Posted by statesman View Post
    Reset the fuel trims.
    Trims are off in the tune. The ltft does seem to have figures in them. But surely they are not doing anything?
    Thanks Antony
    Holden Commodore GTS - LS1 5.7
    12 rib Crank Driven Vortech V2 Centri Charger (Intercooled) 9 PSI.
    LS6 Intake
    LS6 Heads
    YT 1.7 Roller Rockers
    BTR Dual Spring with Ti retainers
    BTR Hardend 7.400 Push rods
    Comp Cam JAMCAM
    2 Bar Map
    Mafless
    LS2 Coils
    PCM LS1B with 512KB Running COS5 v01290005
  2. #12
    Feb 2006
    the e38/67 controllers are a strange beast. they will do weird fueling after a flash. generally after a restart i find fuel mixtures on light load/idle will be a bit silly and then come into line shortly after a small drive or high map scenario.
  3. #13
    Apr 2010
    So how do you tune the VVE? For idle or driving? Then let the fuel trims sort it?
    I get you will never have a perfect VVE due to the way it works and has to be linear in a zone removing curves in some areas.
    The issue is the VVE is so far off in both directions that you sort one the other is massively screwed. It's still feeling like an adder table.
    Thanks Antony
    LS6 Intake
    LS6 Heads
    Comp Cam JAMCAM
    2 Bar Map
    Mafless
    LS2 Coils
  4. #14
    Feb 2006
    Sorry, what i meant was you need to give the ecu some time after doing a flash for it to stabilize.
    for example i often find that i can have spot on fuel trim for idle/cruise etc. but once i do a flash. restart. the idle will either be pig rich or lean. it varies from ecu to ecu.
    It's partly to do with the IVT calculations & some other hidden background crap that goes on with them. It's especially more common on SD only tunes.
    So dont go making changes to idle vve, log stationary idle. reflash and expect much to change or you'll end up chasing your tail.
    Another thing to change for sure is how you setup the fuel g/sec table under the fueling tab. you have the same airflow fuel "multiplier" for 0-160kph. working with that can do wonders.
  1. Fast Idle
    By LIL DAVE in forum General (Diesel)
    Last Post: January 8th, 2013, 07:53 PM
  2. can a lean idle or going lean during light cruise harm the engine?
    By ryans1000 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 3rd, 2009, 01:44 PM
  3. Efi live and factory fast idle
    By maxxflip in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 17th, 2009, 02:50 PM
  4. what table controls how fast it drops to idle when slowing down?
    By mvvette97 in forum Gen III V8 Specific
    Last Post: September 8th, 2009, 09:18 PM
  5. Good VE numbers except at idle?
    Last Post: June 3rd, 2007, 12:39 PM
