Need a stock file for 5.9, Here is the vin #
3D7KS28C66G117251
Thanks!
3D7KS28C66G117251
Thanks!
[/SIGPIC]
2005 duramax LLY, 12.75 on stock motor/fuel, 68mm vgt built trans.
Built motor by me, built trans, EFIlive by me, dual fuelers, 80% injectors.
Bump
[/SIGPIC]
Well does anyone know where I can get one since 4shared doesn't have em anymore
[/SIGPIC]
What OS are you looking for?
Whatever OS there is for that vin. I can't pull the tune from truck to see.
[/SIGPIC]
You can query the ECU to see what OS it's running via the V2.
Automatic or manual? Can't tell anything about the OS from the vin.
It's a automatic, crew cab 4x4, shifter on the floor.
[/SIGPIC]
Full set of Cummins and Duramax Stock Tune Files
https://forum.efilive.com/showthread...ax-Stock-Files
Thank you
[/SIGPIC]
