Results 1 to 10 of 11
Thread: 2012 5.3 truck with 6l80e (vette tune) won't move.
    Aug 2012
    Default 2012 5.3 truck with 6l80e (vette tune) won't move.
    Swapped a 2012 5.3 e38 with 6l80e into a 62 Willy's wagon. Also installed a speartech tap shift shifter from speartech and flashed in a Vette t43 tune. Engine fires right up but when I put in any gear I have no movement at all. Engine just revs up.
    At first I had a p0700 and u0100 code (also still have a map voltage low code) but I turned those off. Still no go. ECM and TCM flashed through the obd plug so comm should be fine. Accessory wakeup voltage has 12v.
    This is a customer vehicle who just received some bad news and is trying to enjoy what time he has left. I'm trying to get this done asap for him
    Any ideas? Thoughts?
    Aug 2012
    VIN says engine is a 2012 and OS is 12647991
    Vette TCM OS (unsure of year) is 24261871
    Are these compatible? Is there anything I need to do to verify tcm and ecm are talking? When I try to log t43 I get "generating error.... out of range $03"
    With the scantool, there are some pids you can log which show the state of the gear selector lever, the current gear, and other TCM status...
    Aug 2012
    Anything wrong with using a 2013 TCM vette flash with the 2012 truck ECM flash?
    May 2012
    it should work 2012 ecm and 2013 tcm but if you can do a 2012 tcm corvette flash with GM MDI or GM tech2 it should work, do you have low voltage code on the tcm? there is a way to phisically fix it, you cant fix that code with the tune.. with engine running try to delete codes and put it on gear , let me know what happens
    Aug 2012
    Ok I have since flashed the original TCM truck tune in and still no output movement no matter what I do or what gear I'm in. I am getting a trans temp reading when logging so I assume communication is good.
    Are there ANY basic tests I can do to rule out trans mechanical issues vs electronics? Should I hear solenoids clicking when I use the DVT tab? Are there any PIDs I can monitor for basic diagnosing?
    I am not getting any TCM codes at the moment. None are deleted in the TCM since I just reflashed it.
    Please help
    Aug 2012
    Is there any way I can command first gear with efilive? Simply putting in drive doesn't not do anything. Fluid is topped off.
    Aug 2012
    Hope this helps. I logged pretty much all trans PIDs and let engine idle. I then went through the gears. scan tool shows shifter position and 'gear' says 1 so I assume its commanding 1 but nothing is happening??? Output speed says 0 but it almost feels like engine load changes slightly when going in D or R
    Gear changing starts about frame 220
    t43.efi
    These are the current tunes
    read t43.ctz
    read e38.ctz
    Aug 2012
    Issue resolved. The mechanic that installed the trans did not put a filter and pickup tube inside the trans. Unbelievable. It was just sucking air. 5 hours of diagnostic time wasted second guessing my harness and tune.
    Quote Originally Posted by bubba68ss View Post
    That's a pretty bad fail.
  1. After a 2011 t43 vette tune / 6l80e troubles
    By vassis in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: December 11th, 2017, 02:45 AM
  2. Wanted 2011 and 2012 6l80e T43 Corvette Tune I will pay for it
    By RD in SD in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: February 3rd, 2016, 06:08 AM
  3. swapping Camaro 6l80e to Vette 6l80e
    By secrt007agt in forum General
    Last Post: January 31st, 2016, 04:43 AM
  4. 2012 Vette 6l80 tune in older trans for faster tap up tap down and rev matching
    Last Post: January 24th, 2015, 01:36 PM
  5. Truck won't run when MAF is disabled for SD tune
    By kbracing96 in forum Gen III V8 Specific
    Last Post: May 2nd, 2013, 04:43 AM
