Results 1 to 10 of 10
Thread: Logging issue
    Aug 2015
    Default Logging issue
    My v2 up and decided it doesnt wanna data log some of the pid's, i cant data log a cmd, or cmd at all or the eda's on a cmb but can log balance rates, im runnind v82.2.303 and my v2 is up to date. Any thoughts?? Thanks
    Lifetime Member Move'n Up's Avatar
    Oct 2015
    I assume these are PID's that you were previously able to log? Have you confirmed your BBX setup to confirm that the PID's are loaded in the V2 BBX config file?
    2006 Ram 2500 4x4, 5.9 CTD, Laramie, QC
    Fully Built 48RE, Billet Flex Plate, Triple Disc TC, 62/65 HE351cw
    2017 Corvette 3LZ Z06 M7 with Z07 Package
    Aug 2015
    Yup, the set up properly and could always log them before
    Oct 2015
    Is this the same vehicle(s) as before? Does the truck have a CSP5 tune loaded? Unless a CSP5 upgraded OS is loaded then you will be limited to what you can data log.
    Aug 2015
    Yup same vehicles as always.
    Sent from my iPhone using Tapatalk
    Oct 2015
    Yea, that is odd.
    Maybe something happened to the file on the V2. I'd try to rebuild and then reload your BBX setup config to your V2 or just reload your BBX setup that you currently have on your PC.
    Aug 2015
    very odd, and did that a couple times
    Oct 2015
    I'm all out of troubleshooting and possible solutions then, sorry.
    Hopefully someone else will chime in here.
    Quote Originally Posted by PHIL@ARMORINC View Post
    When you say "can't log" what error do you see? (if any error at all).
    Aug 2015
    No error code. Just reads 0's. Except for rpm's
  1. Data Logging Issue
    By tdsabo in forum Cummins 5.9L
    Last Post: March 31st, 2016, 03:38 PM
  2. Custom Dashboard Logging Issue
    By PHLTHS in forum Black Box Logging
    Last Post: November 9th, 2015, 10:22 AM
  3. LM-1 logging/map issue
    By playtoy_18 in forum External A/D inputs
    Last Post: January 17th, 2014, 09:04 AM
  4. PSL Logging issue
    By Cougar281 in forum FlashScan V2 BB Logging
    Last Post: April 29th, 2008, 12:30 AM
