Results 1 to 8 of 8
Thread: Desired IAC airflow vs. calculated airflow rate
    May 2015
    Default Desired IAC airflow vs. calculated airflow rate
    I noticed there was a 3 gms/sec discrepancy between these 2 and am wondering what I can do to get them closer. I'm using the 12613248 OS with a 1 MB PCM to control a stroked 2002 Z06 engine with ported heads and a 228/232 .615/.600 116.5+3 camshaft and a ported throttle body. Yesterday I experimented with the IAC effective area yesterday and was able to get it closer by moving all the cells down 5 or 6 places but that doesn't seem like a good solution to me. Log_0100a.efi82 Corvette baseline_0016.ctz
    Aug 2013
    Quote Originally Posted by Illegal Vette View Post
    It might not seem like a good solution to you, but it's the correct solution.
    May 2015
    I'll give it a try then, thanks for your reply!
    May 2015
    That did the trick, thanks for your help!
    Good job
    BTW: you should fix these:
    Out of Range calibration summary: 06:02:56 pm, Wednesday Nov 09, 2016
    Engine Calibration.Fuel.Mixture
    {B3614} Hot PE Mode Coolant Temp Threshold, was out of range when loaded.
    Engine Calibration.Fuel.Lean Cruise
    {B3636} Vehicle Speed Lean Cruise Enable, was out of range when loaded.
    Engine Calibration.Fuel.Trim
    {B3803} Maximum Coolant Temp to Enable LTFT, was out of range when loaded.
    To fix them (there is a quirk in the V7 tunetool), you have to set them to max-1 or min+1, save file, exit tunetool, reopen tunetool and set them back to intended max/min value, and save file.
    Aug 2013
    Enjoy!
    May 2015
    Thanks for that, it worked just as you said!
  1. Desired airflow COS3
    By Janke in forum Custom Operating Systems
    Last Post: May 2nd, 2012, 12:33 AM
  2. Desired airflow won't equal measured airflow
    By Ryan in forum Gen III V8 Specific
    Last Post: June 4th, 2008, 09:17 AM
  3. Desired Airflow
    By Thumper in forum Gen III V8 Specific
    Last Post: April 23rd, 2008, 02:23 AM
  4. IAC-A/C Airflow (IAC_AC_DMA)
    By ssheets in forum Gen III V8 Specific
    Last Post: January 27th, 2008, 04:15 PM
  5. Question about calculated airflow vs. measured airflow
    By JR_VETTE in forum General (Petrol, Gas, Ethanol)
    Last Post: October 1st, 2006, 05:37 PM
