Results 1 to 6 of 6
Thread: Rail Pressure tuning
    Jan 2016
    Default Rail Pressure tuning
    I'd like to pick some guys brains. I'm looking for some advice on tuning Rail pressure to follow desired quicker when the throttle is stabbed as well as best ability to get the most out of a pump. Seems like all the tuning i do actual doesn't meet desired for a second or two and sometimes even longer but then i'll data log another tune in a truck with the same PW and rail pressure follows way faster. Any insight and knowledge behind it would be greatly appreciated!! Also if someone could explain to me the differences in what's going on with the new 10+ trucks and how the regulator is controlled as all the tuning side is completely different from that of early 6.7 and 5.9s. Thanks in advance!!!
    Nov 2010
    Lessen the pulse when your stabbing the throttle
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
    Jan 2016
    Quote Originally Posted by 2007 5.9 View Post
    In most of my tunes i do. I pull the PW down below what WOT is at by very signifigant amounts from 80mpa clear to 140mpa. I've attached a picture of how i normally do them. Disregard the data log int eh screenshot as it is for a different truck/issue. My computer just wont save a crop for some reason.
    Or are you referring to a completely different method?
    Jan 2016
    Why do you modify rail pressure? It seems like this should be pretty close to stock but I am for sure still learning.
    Lifetime Member LB72004's Avatar
    Dec 2011
    Try pressing [alt] + [prt scr] (you my need to also hold down the [FN] key) to screen shot the active window instead of the whole screen. Then you can paste it into paint or the program of your choice to crop it down
    2008 Chevrolet 3500HD DRW LTZ
    285/75/17 Nitto Dura Grapplers, 4.56 gears, Front and rear ARB lockers, Efi Live tuning by me, Raptor 160 LP, Cognito 4-6 NTB Lift, 4" Exhaust, Built Trans by Mike L.
    Sold - 2004 LB7 Duramax, EFI Live with DSP5 Tune
    stage 4 SC transmission, 265/70/16 tires
    Senior Member tylerltr450's Avatar
    Aug 2014
    Just use the snipping it tool built into windows for screen shots.
    2006 Cummins Red, Auto to Nv5600, SBC 3600, Traction Bars, Visor, Running Lights, S&B Intake, ATS intake horn, EFI Live, Borg Warner S363 Turbo, Industrial Injection Dragon Fly Injectors.
  1. Help with rail pressure
    By catman3126 in forum Cummins 5.9L
    Last Post: May 13th, 2015, 05:22 AM
  2. LMM rail pressure
    By DuramaxPowered in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 1st, 2012, 05:36 PM
  3. Rail Pressure
    By mstordahl in forum Cummins 5.9L
    Last Post: June 11th, 2012, 11:27 PM
  4. Rail Pressure tuning help?
    By AdamRRT in forum Cummins 5.9L
    Last Post: October 24th, 2011, 01:00 PM
  5. fuel rail pressure
    By drdarthinvader in forum General (Petrol, Gas, Ethanol)
    Last Post: January 8th, 2009, 07:17 PM
