Results 1 to 10 of 14
Thread: PCM driven shift light on an auto
    Oct 2007
    Default PCM driven shift light on an auto
    I am using 01290005 operating system and trying to use the air pump output pin red plug pin 36 to drive a shift light at a programmed RPM.
    Activated air pump in the platform and adjusted the setting in the Air pump parameters did not work.
    While I am running 01290005 operating system which was converted from an Australian operating system is it possible the Australian operating system/tune does not have the relevant information to drive the air pump output!
    Can anyone offer any suggestions?
    Look at G1206/G1207.
    Oct 2007
    Thanks for the reply I have already set G1206/G1207
    Also
    B0201
    B0202
    B0203
    B0204
    B0205
    B0206
    B0207
    have been addressed.
    Mar 2007
    Do you have to turn on the DTC's to get it to function? C6001 ---> P0410, P0412, P0418? Set them to something like Non Emissions
    Quote Originally Posted by turbo_bu View Post
    I'm not sure...
    ( I know disabling the DTC's prevents the Secondary AIR tests from running )
    it might be best to try it and see.
    Oct 2007
    Interesting!.....I will try it and report back thanks.
    Mar 2007
    I'm not sure...
    I guess I meant to say just turn on the sensor, and maybe not the actual Secondary AIR test DTC. Either way, I think that you have to tell the PCM that something is there before it will turn it on.
    Yes, I agree, PCM has to be told to look for it.
    Jul 2015
    Im also interested in this im using a auto trans os but a th400 tried shift light output with a led and it blinks untill set rpm then goes solid i would love to a different output to make this work
    Oct 2007
    Tried all the settings this did not work either!
  1. E40 PCM shift light output? And fan
    By bikealarmblair in forum Gen IV V8 Specific
    Last Post: June 27th, 2012, 07:06 AM
  2. E40 PCM shift light output? And fan
    By bikealarmblair in forum Gen III V8 Specific
    Last Post: June 27th, 2012, 02:14 AM
  3. Can the 1-4 shift light be controlled on the e38s like the 0411 PCM?
    By Highlander in forum E37, E38 & E67 PFI ECM's
    Last Post: March 10th, 2011, 12:33 PM
  4. Using the pcm controlled shift light
    By Chris81 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 4th, 2008, 04:56 AM
  5. shift light
    By RUTAN TA in forum General (Petrol, Gas, Ethanol)
    Last Post: July 17th, 2006, 05:07 AM
