Results 1 to 4 of 4
Thread: LS1B with 3bar custom os scan tool map pid only reads to 255kpa need to see up to 285
    Jul 2015
    Default LS1B with 3bar custom os scan tool map pid only reads to 255kpa need to see up to 285
    LS1B with 3bar custom os scan tool sae.map pid only reads to 255kpa need read up to 285kpa the same as the boost ve table is there a way to change the sae.map to read 285kpa or o i need a new map so i can log boost past 255kpa need help please
    Don't use SAE.MAP, it will only go to 255kPa (not much we can do about that).
    Now I don't recall the exact PID to use for the LS1B but look for 'GM.MAPBOOST_DMA', 'GM.MAP2' or 'GM.MAP3' instead if those are valid for LS1B.
    Jul 2015
    only one that i see but couldnt check value is map sensor MAPBOOST_DMA the more info tab is blank do you think this is it. i did notice that the pcm went above 255kpa when in my run but in my map for ben hit a wall at 255kpa and im running 28# boost
    Jul 2003
    do map voltage and just apply the scaling on a calculated PID if none of that works.
  1. 3bar COS only logging to 255kpa
    By BAD BOB in forum Custom Operating Systems
    Last Post: August 29th, 2015, 08:40 AM
  2. Map sensor problem in efi live scan tool
    By zayne0 in forum Petrol / Gas
    Last Post: October 22nd, 2014, 11:17 PM
  3. 3bar COS logging only to 255kpa
    By BAD BOB in forum FlashScan V2 BB Logging
    Last Post: June 28th, 2013, 02:01 AM
  4. Can't select RAFIG PID's in either BBL or Scan tool!
    By kwhiteside in forum Gen III V8 Specific
    Last Post: July 22nd, 2009, 01:53 PM
  5. Changing from a 2bar map to a 3bar map?
    By onfire in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: December 23rd, 2006, 03:31 PM
