Results 1 to 7 of 7
Thread: E80 1.5L LFV Dyno controller
    Nov 2016
    Default E80 1.5L LFV Dyno controller
    I am starting to look into using an E80 contoller on the new 1.5L turbo LFV on an engine dyno. I have a controller powered up on a bench and will be trying to communicate with it later today.
    One of my concerns is the TCM communication. I'm not entirely sure if I will have to spoof these signals, if I can ignore them and it wont be a problem, or if there is something I can change in the OS/Cal to make this work properly.
    I looked through the stickies and some of the posts in this forum, but it looks like most of the controllers that people are using are older, so may not run in to these issues. Has anyone been successful with an E80?
    Thanks,
    Not sure for this particular controller, however if it does weird things like put you always on a 4000rpm rev limiter, you might have to run a manual OS (if possible) or disable the trans component. To spoof the CAN comms, might have to put a resistor inline.
    Nov 2016
    What would the best way to disable the transmission component be?
    There is no manual option for this (2016 Chevrolet Malibu LFV), but I am wondering if the 2016 Cruze with the LE2 has an OS that would work. I don't know where I would find one that I could download the cal from though.
    Erik is right, if you can find a manual trans version as the base tune you will save yourself a lot of grief.
    Edit: I posted the same time as you. There isn't really a 'auto / manual' switch, there is hundreds (maybe thousands) of underlying calibrations that change depending on the trans type.
    Is there any other vehicle using that engine that ran a manual trans? An Opel maybe?
    Nov 2016
    I guess I will begin the hunt for a 2016 Cruze manual 1.4T.
    I have an automatic cal and it looks like all the table assignments are the same, so that might be a good option.
    How different is the 1.4L (LE2) and 1.5L (LFV) as far as what you are trying to test?
    Nov 2016
    They're both SGEs on E80s, so control wise I think they're very similar. The cal for the automatic LE2 looks very similar to the LFV, even the injector sizing is the same.
    I have hardware that I want to test that is specifically designed for the 1.5L already, so I am constrained by that, unfortunately. If it we're earlier on in the program, the 1.4L may have been a better choice just because of the availability of a manual trans...
  1. E80 - Cam Position PID Missing
    By Giambals in forum Petrol / Gas
    Last Post: December 12th, 2016, 03:12 PM
  2. S10 Petrol - Delco E80
    By GabrielMga in forum General (Petrol, Gas, Ethanol)
    Last Post: July 9th, 2015, 08:53 AM
  3. Vortec PCM/Controller not listed under DVT controller selection.
    By Scatfish in forum Vortec V6/V8 Specific
    Last Post: April 5th, 2015, 11:10 AM
  4. V2 controller
    By twinki025 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 23rd, 2007, 04:27 PM
  5. Dyno success on Dynolog Dyno
    Last Post: April 1st, 2006, 11:31 PM
