Results 1 to 5 of 5
Thread: E80 Boost target
    Nov 2016
    Default E80 Boost target
    How is the boost target handled on the E80? I can not find a boost target table, so I am assuming it is calculated?
    We are going to add in some more boost related tables soon, there is probably not enough in there at the moment for full control.
    Nov 2016
    OK great. I'm learning the E80/EFI Live as I go so sorry to keep asking question. Doesn't seem like there is much info out there on it yet. Is there an injector flow table missing as well, or does this controller just assume linear pulsewidth / injection rate relationship until it hits the small pulse threshold?
    I think we had an injector flow value in the E39 SIDI ECM, it isn't a table like in the older ECM's, just a single value. Because injector swaps aren't really happening on the E80 cars yet we've not gone looking for it.
    Nov 2016
    Is it possible to get the correct MAF calibration table added to the E80 controller? It looks like both MAF Frequency conversion and MAF Frequency conversion 2, but neither seem to be correct for this MAF sensor.
    I logged MAFFREQ2 and MAF while driving and got the following scattered data (I'm assuming some transient airflow model is being added to the MAF pid). This would be immediately useful for the work I am doing.
    I also noticed that oil pressure sensor voltage works properly, but oil pressure does not.
    And can you check the desired fuel rail pressure table? I logged desired and actual fuel pressure while mapping, but the tables don't seem to match the commands.
  1. E80 - Cam Position PID Missing
    By Giambals in forum Petrol / Gas
    Last Post: December 12th, 2016, 04:12 PM
  2. E80 1.5L LFV Dyno controller
    By Giambals in forum Conversions / Aftermarket Parts
    Last Post: November 18th, 2016, 10:34 AM
  3. S10 Petrol - Delco E80
    By GabrielMga in forum General (Petrol, Gas, Ethanol)
    Last Post: July 9th, 2015, 09:53 AM
  4. High RPM (3500-3900) boost issue... not reaching target??
    By GeneralTJI in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 20th, 2010, 05:58 PM
  5. Too much boost and Turbo Vane "TARGET" Position-LMM
    Last Post: November 5th, 2009, 09:27 AM
