Thread: Look for a stock tune for Silverado 2500 2010-2015 6.0L w/ flex
    Oct 2010
    Default Look for a stock tune for Silverado 2500 2010-2015 6.0L w/ flex
    I picked up a set of 12613412 injectors and would like to take a look at the stock tune.
    I didnt see one in the depot.
    Fits Following Make / Model :
    Express Van : 2010-2015, 6.0L
    Silverado 2500 Pickup : 2010-2015, 6.0L
    Silverado 3500 Pickup : 2010-2015, 6.0L
    Savanna Van : 2010-2015, 6.0L
    Sierra 2500 Pickup : 2010-2015, 6.0L
    Sierra 3500 Pickup : 2010-2015, 6.0L
    Suburban : 2010-2014, 6.0L
    Yukon Denali : 2010-2014, 6.0L
    Yukon XL Denali : 2010-2014, 6.0L
    Member Whipped383's Avatar
    May 2011
    Looking for the same but I need gen3 tune data for them. By chance do you know the engine code?
    97 K1500, 383, 4L60E, Whipple, Stock 14 Bolt with 3.73, EFILive V2, 0411, Marine, #42 Injectors, H-Boost, LC-1, Coming Soon: Intercooler, Trutrac, 4.11 gears?
    03 K2500HD, 8.1 and Allison, Stainless works long tubes, Intake mods
    Oct 2010
    Quote Originally Posted by Whipped383 View Post
    I *think* L96
    http://surefireengines.com/cgi-bin/infop?DCT13
    If it's L96 then see this post by Wipped383 in another thread: Correct-IFR-tables-for-LS3-LS7-injectors-in-Gen-III~post#132
    Oct 2010
    Thanks @joecar!
    One last question. since the IFR is done via delta kpa. If the injectors are rated at 3bar but will be running at 4bar, do I need to scale the table by 1.1614 [sqrt(58/43)] or will the delta cover this?
    You will still need to scale the injectors... scale by sqrt(58.0/43.5) = 1.1547 (since 3 bar is 43.5 psi).
    Delta kPa refers to the pressure difference between top of injector (at rail pressure) and bottom of injector (at manifold pressure)...
    if FPR is 4-bar (58 psi, 400 kPa) the absolute rail pressure is 500 kPa;
    MAP (manifold absolute pressure) ranges from 30 kPa (closed throttle decel) to 100 kPa (WOT);
    so delta kPa ranges from 400 kPa (WOT) to 470 kPa (closed throttle decel).
  1. Replies: 27
    Last Post: May 27th, 2022, 04:18 AM
  2. EFI LIVE for stock 2010 dodge ram 2500
    By DODGE-2010 in forum Cummins 6.7L
    Last Post: September 7th, 2016, 07:39 AM
  3. 2015 dodge 2500 looking for some help
    By bmr408 in forum Cummins 6.7L
    Last Post: April 18th, 2015, 03:43 PM
  4. stock tune for 4.8L V-8 silverado
    By nickyreno in forum General (Petrol, Gas, Ethanol)
    Last Post: October 24th, 2007, 06:52 PM
