Results 1 to 7 of 7
Thread: CAX Still working for ALL OS?
    Nov 2014
    Default CAX Still working for ALL OS?
    Below is what I'm attempting to get to show up in the Cal "32140305". I pasted the file into the calibration folder and even in the sub folder "CME". I have enabled CAX files in my properties as well.
    I can't get ANYTHING from the CAX to show up when I open the tune. This is one of my first miserable attempts at this.
    [E9801]
    DESC.001 = Used to enable or disable hardware.
    Desc.002 =
    Desc.003 = NOTE: This could really tear stuff up
    VIEW = 1 "Fitted With Module" "Vehicle Options" "Test Name" 1 1 0 0
    ADDR = 00D57D 0 16 SED 0
    SI_SLOT = e/d 1 0 0 0 1 0 1
    ULABELS = . . .
    SI_ENUM = "1=Enable,0=Disable"
    IM_ENUM = .
    SI_COL = .
    SI_ROW = .
    Quote Originally Posted by SmokeAintPower View Post
    That E9801 shows up when I test it here.
    Is it possible that your filename is actually set to 32140305.cax.txt. You would not see the .txt on the end of the filename if Windows Explorer is set to "Hide extensions for known file types".
    Nov 2014
    I have extensions set to visible. It's labeled as 32140305.cax and placed into the directory C:\Program Files (x86)\EFILive\V7.5\Calibrations & C:\Program Files (x86)\EFILive\V7.5\Calibrations\CME
    Could you by chance provide me with the .cax file copy you made? I'm really confused at this point.
    Did you check in the "EFILive Custom Calibrations" area?
    That's where it showed up when I tested it.
    The table id is E9801 (from post #1), why does it show up in the A segment...?
    It's defined to be in segment 1. That actual name is irrelevant.
    Code:
    [E9801]
    ;         Description
    Desc.002 =
    ;         Seg Caption                               Major                        Minor           Vis Dis 2D Grp
    ;         Address(es)                      BitOff Bits Typ Inv
    ;         Units           Factor         Offset Prec MinLimit MaxLimit MinUser  MaxUser
    ;         Body           Col            Row
    ULABELS = .              .              .
    ;         Enumerations
    IM_ENUM = .
    ;         Units            Labels
    SI_COL =  .
    IM_COL =  .
    SI_ROW =  .
    IM_ROW =  .
    Ah, of course, I remember now. Thanks.
  1. Cax Question
    By Chavez91 in forum CAX Files
    Last Post: July 13th, 2017, 06:13 AM
  2. CAX DTC's
    By DURAtotheMAX in forum CAX Files
    Last Post: April 13th, 2015, 03:10 AM
  3. loading in the .cax
    By RADustin in forum CAX Files
    Last Post: June 13th, 2014, 11:03 AM
  4. cax file?
    By myws6formula in forum CAX Files
    Last Post: December 21st, 2008, 04:00 PM
  5. .cax confusion!!!
    By Lextech in forum CAX Files
    Last Post: September 26th, 2008, 02:25 PM
