Results 1 to 10 of 12
Thread: Checksum $06FF
    Feb 2012
    Default Checksum $06FF
    Hi,
    I tried to flash a modified tune into a Camaro 6.2 engine. At the end of the flash got a "Script Exited with Code $06FF-Checksum Failure". (The car was already modified by another tuner)
    Also try to record the original, But not crank or run.
    How can I solve the problem?
    May 2010
    Try flashing using V7.5
    I had this problem many times for cars tuned before with Diablo which cause some issues and it should be flashed using V7.5
    EFILive Tuner
    Use this file instead, wesam's description of the problem is correct.
    Feb 2012
    Thanks for the quick reply for file-fix!! I now update my Flashcan and reflash the car !!!
    Thanks again.
Name:	Captura de Tela 2016-12-04 às 22.59.41.png
ID:	20520   Click image for larger version.
Name:	Captura de Tela 2016-12-04 às 22.59.22.png
    Oh sorry, I forgot I was running a very new installation, you can get it from here.
    https://forum.efilive.com/showthread...a-Test-Release
    Feb 2012
    Fantastic!!! The car running OK
    Thank you very much for the support!!!!
    Feb 2012
    Default Anothe Camaro, same problem
    Hi,
    I have another Camaro with same problem, can you fix this please ???
    Thanks !!
    Feb 2012
    Thumbs up
    Ohh!! Very very thanks for your support !!!
    Dec 2009
    I have an E92 with same issue 15 z06 manual op 12666661
  1. E40 checksum Error $06FF
    By clm7182 in forum Gen IV V8 Specific
    Last Post: April 26th, 2015, 10:12 AM
  2. 06FF Checksum Failure on E38 PCM for 06 Z06
    By injected in forum Gen IV V8 Specific
    Last Post: April 1st, 2015, 08:58 AM
  3. Checksum error code $06FF with L92 PCM
    By 67SS509 in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: December 5th, 2014, 02:51 PM
  4. T43 TCM code $06FF: checksum failure
    By 400ss in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: August 15th, 2014, 10:26 AM
  5. Replies: 2
    Last Post: July 17th, 2012, 04:27 PM
