Results 1 to 10 of 11
Thread: COS5 egr "not supported"
    Jun 2016
    Default COS5 egr "not supported"
    I have a 98 f-body swapped to a 99 pcm running the COS5 OS. I'm concerned that the egr system shows "not supported" in the emissions System Readiness Test. When that parameter doesn't match my '98 VIN build that will fail an OBDII test correct? Any help?!
    Jun 2016
    I believe I am allowed one "not ready" before failing. Would a "not supported" fall into the same category maybe?
    Quote Originally Posted by B18B1LS1 View Post
    No, in CA they now require NONE not-ready.
    The not-supported will raise an alarm on the CARB central computer (so to speak) in Sacramento because the car came with EGR supported.
    Look at the EGR DTC's in C6001 and set them to either A or B.
    Jun 2016
    I think this post answered my question
    https://forum.efilive.com/showthread...-25-2013/page3
    '98 Z28 S475
    It did (I'm getting old)...? Which post...?
    Jun 2016
    I'll have a look at c6001 this evening. If it helps I'm in Georgia where the tests aren't quite as bad as California I hope.
    '98 Z28 S475
    Jun 2016
    There is a good chance I misinterpreted what you guys were talking about in the post I linked. I thought you were basically saying a "not supported" would read "ready" at the emissions test.
    '98 Z28 S475
    Jun 2016
    I guess I also should have mentioned I don't have an EGR system anymore.
    '98 Z28 S475
    Yes, a not-supported shows up as ready.
    ... I'm in Georgia...
    Ah, ok, in your case set all the EGR DTC's in C6001 to Not-Reported, and set all the same DTC's in C6002 to MIL (as in MIL enabled).
  1. Getting message "CASE not supported in this controller" for E67
    By Low03noma in forum E37, E38 & E67 PFI ECM's
    Last Post: August 18th, 2013, 01:02 PM
  2. scantool "mode not supported"
    By gbi1988 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 15th, 2011, 03:07 PM
  3. EFILive "Classic"/"Legacy"/"Historic"?
    By emarkay in forum FlashScan V2
    Last Post: November 2nd, 2008, 02:48 AM
  4. Unsupported PID's? Making them "supported"
    By N0DIH in forum General (Petrol, Gas, Ethanol)
    Last Post: October 7th, 2008, 10:40 AM
  5. Can V2 read "non supported" cars?
    By Dale in forum General (Petrol, Gas, Ethanol)
    Last Post: March 19th, 2008, 02:21 PM
