Results 1 to 4 of 4
Thread: 8bit binary
    Dec 2013
    Default 8bit binary
    Is it possible to show an 8bit binary value with CAX? I cannot for the life of me figure out how to show base2 binary in V7.5 with a CAX definition.
    Jul 2003
    you can use bit offset to do this.
    Set display to 4 too.
    Jul 2003
    Or like this if you want to set it individually.
    Code:
    [M5664]
    ;         Description
    DESC.001 = If TRUE is specified for the indexed fault group, then any active fault within that group will inhibit the Misfire diagnostic.
    ;         Seg Caption                                                     Major             Minor  Vis Dis 2D Grp
    VIEW =      3 "Param"                                        "Misfire"                        ""   1     1  0   0
    ;         Address(es)                      BitOff Bits Typ Inv
    ADDR =   XXXXX                               1    1 SED   0
    ;         Units            Factor         Offset Prec       MinLimit       MaxLimit        MinUser        MaxUser
    SI_SLOT = True/False          1.0              0    0              0              1              0              1
    ;         Body           Col            Row
    ULABELS = .              .              .
    ;         Enumerations
    SI_ENUM = "1=True,0=False"
    IM_ENUM = "1=True,0=False"
    Dec 2013
    Quote Originally Posted by Highlander View Post
    Thanks for the reply, I actually figured that one out then subsequently, temporarily, broke EFI live and emailed Paul about it. It is being addressed in the next release.
  1. Stock binary segments
    By computerjlt in forum E47 LUZ 2.0L (Family-B) Diesel
    Last Post: August 11th, 2016, 03:48 PM
  2. Holden 2005 LS1 binary...
    By SSbaby in forum General (Petrol, Gas, Ethanol)
    Last Post: August 2nd, 2006, 02:59 AM
