Results 1 to 4 of 4
Thread: idling and cutting out whe it sees boost
    Apr 2011
    Default idling and cutting out whe it sees boost
    Angry 2004 Turbo Silverado PlEASE HELP!!
    OK SO I am still having problems with Idling especially coming to a stop its always dying. The other big problem is that as soon as it starts to go into boost it starts making a cutting out or something. Now keep in mind and what is so frustrating to me is that a month and a half ago It was running so good and making tons of boost (more that I wanted it to make so I was reducing the boost little by little until I got just under 10psi. I then drove it about 60miles and it through connecting rods through the side of the engine and a couple through the bottom and this was way after the high boost and I just had the cruise set for the trip down to kc when this happened but it ran flawlessly. then I find another engine and since I had already ordered a comp cam turbo cam I went ahead and installed that while it was on the engine stand. I also used the factory 317's, new gaskets. now every since I got this engine I have done all the checking I can think of as far as making sure each plug is firing, to a new crank sensor, fuel pressure... Last night I actually pulled the front off the engine and made sure he marks still were lined up. I am just out of Ideas Someone or several people take A little time out of your life to graph my data log and if you feel like you found the problem go ahead and fix it and send it back and will see if that was the problem PLEASE!!! Sincerely, Bryan
    turbo silverado 12 3 16 to dads farm and back to mine.efi
    SILVERADO TURBO STUDER TUNE 12 3 16.ctz
    Sep 2006
    You didn't attach the files for us to look at.
    Apr 2011
    That is what those last couple sentences are with dated on them but a lot has changed since then anyways. Wish it was easy to just delete a post.
    To delete a post, click Edit Post, then click Delete, then select Physically Remove Message, then click Delete Post.
  1. E38, FI, boost, cylinders cutting out. Help!
    By arubenstein in forum E37, E38 & E67 PFI ECM's
    Last Post: December 31st, 2014, 02:55 PM
  2. Lmm question? do they kill the fuel until it sees tire speed?
    By Dragbear in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 21st, 2013, 04:59 AM
  3. Help with Idling high for a few seconds.
    By nchristian in forum Gen III V8 Specific
    Last Post: February 2nd, 2011, 04:42 PM
  4. E0281 but sees VIN
    By VHR in forum Black Box Logging
    Last Post: December 20th, 2010, 08:46 AM
  5. A/C Idling extremely rough
    By Highlander in forum General (Petrol, Gas, Ethanol)
    Last Post: October 28th, 2006, 10:10 AM
