Results 1 to 10 of 10
Thread: Stock E82 files
    Jan 2006
    Default Stock E82 files
    Would anyone post there stock E82 files (LGX engine) and matching TCM file (Camaro/Cadilac)? I don't care what vehicle there from I just want to compare them to mine.
    Here is mine= 17 GMC Acadia
    Edit: It's now supported
    Robert
    04 LB7
    2010 LMM
    2015 LML
    Jul 2011
    Thanks Robert for your Acadia files. I'll have a solid look over them and will post a 2016 Camaro LGX file once I find out how to read it out from efi live (sent an email).
    Jan 2006
    Cool thanks, open the scan/tune software (V8), click on help, then documents, and the controler auth instructions are in the list you will have to purchase a auth code to do anything with the tune (read/write).
    http://www.efilive.com/controller-auth
    04 LB7
    2010 LMM
    2015 LML
    Jan 2006
    Still no luck finding any E82 LGX stock tunes someones got to have a few?
    04 LB7
    2010 LMM
    2015 LML
    Jan 2006
    Still trying to find a file to look at no luck yet.
    04 LB7
    2010 LMM
    2015 LML
    They haven't taken the tuning world by storm
    Jan 2006
    Yeah I figured why mess with a turd V6 in a Camaro when you could have V8 Im just trying to squeek a few more ponies out of wifes grocery getter the Camaro/Cadillac motor is supposed to be identical but sports around 15hp more.
    04 LB7
    2010 LMM
    2015 LML
    Probably to make it nicer to drive maybe just play around with the throttle response tables (torque req). You think you'd even notice +15 Hp in an Acadia sized vehicle?
    Jan 2006
    I looked again and it's actually a decent difference 25hp, I've messed with it a little already but don't want to be missing out on anything I'm guessing they put different cams or something else but you would think they would give it a different motor designation if something was different.
    04 LB7
    2010 LMM
    2015 LML
    Jan 2006
    Well bumping this up I found the cams have the same p/n's between the Camaro and other LGX motors the difference was the intake manifold probably due to the transverse mounting who knows? Either that or there tuning the torque/hp curve with the different runners instead of the cam. I'm thinking they just lowered the shift points for the crossover LGX motors.
    Oh and still looking for a Camaro/Cadillac stock LGX tune file.
    04 LB7
    2010 LMM
    2015 LML
  1. Replies: 8
    Last Post: April 20th, 2016, 11:24 PM
  2. Stock GEN IV Files
    By Black02SS in forum Gen IV V8 Specific
    Last Post: August 16th, 2015, 08:52 AM
  3. Stock Files
    By BigCE in forum Duramax 2011+ LML / LGH
    Last Post: February 20th, 2015, 04:34 PM
