Results 1 to 10 of 14
Thread: 2000 Silverado with a 7.4
    Member Dirktdolman's Avatar
    Oct 2014
    Default 2000 Silverado with a 7.4
    I have a buddy who has a 2000 Silverado with a 7.4 (454)(I believe a L29). I tried to read his ECU and it returned an error saying it is locked. I checked the supported vehicles list and the 7.4 was not on the list. Will the EFI read the 7.4 ECU?
    2003 Chevrolet Silverado 2500HD 6.0L Automatic 4 X 4
    It probably won't.
    It will be able to scan and log.
    Oct 2014
    Well BUMMER, THANKS
    That's a Vortec Black Box PCM, it should be readable and tunable. However, that controller is End of Life, so what parameters are there are there and will not be looked at again.
    Oct 2014
    What do you mean End of Life?
    Should I still be able to access the settings? If so, what do you think the error is? I only used the V2.
    Development has been completed and will not be looked at again. If there are any bugs/inconsistencies, they will not be addressed. Just like software, they're still available to use and tune, just no updates/fixes will be made.
    Did you select the Vortec Black Box PCM when attempting to read the vehicle? I'd start off with a laptop and try to read it using V7.5 or V8.
    Oct 2014
    I never saw that option on the V2. I will try my laptop next. THANK YOU
    Quote Originally Posted by Dirktdolman View Post
    You would have had to set up the controller in the BBX options and update the configuration files on your V2 for it to appear. Try it out and report back!
    Oct 2014
    I did not go the BBX path. I just hook the laptop up and used the Tune V7.5. I finally got it to download using the L31 Vortec 98-00 PCM. Thanks for heading me in the correct direction. Here is the file I downloaded.
    Paul.ctz
    Feb 2005
    Before you license the vortec computer, consider doing an 0411 ECM upgrade and Licensing that controller instead. There's a hell of a lot more you can do with the 0411 compared to the vortec. Anyway glad you got it figured out.
    2001 Camaro SS
    EFILive Custom OS3
  1. 2000 Silverado 4.3 swap to a 5.3 from 2004 donor Silverado
    By joeboston in forum Conversions / Aftermarket Parts
    Last Post: January 2nd, 2012, 05:14 PM
  2. 2001 Silverado 2wd PCM into 2000 Silverado 4wd
    By LastCall in forum Gen III V8 Specific
    Last Post: April 20th, 2011, 12:52 PM
  3. tuning a 2000 5.3 liter silverado
    By SGFastMax in forum Gen III V8 Specific
    Last Post: October 18th, 2010, 02:52 PM
  4. 2000 silverado efan install
    By nchristian in forum Gen III V8 Specific
    Last Post: January 27th, 2010, 04:54 PM
  5. 2000 Silverado E-Fan Question...
    By GAMEOVER in forum General (Petrol, Gas, Ethanol)
    Last Post: December 29th, 2009, 02:13 PM
