Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: LS1 PCM COS3 Not Reading Boost After Software Upgrade. Anyone else?
    Sep 2006
    Default LS1 PCM COS3 Not Reading Boost After Software Upgrade. Anyone else?
    Thanks for taking a look guys. I've got a 2003 vette running COS3 with a 2 bar map sensor properly scaled. This exact tune was reading boost before I upgraded to a newer version of software. Granted it was a few months ago that the car was tuned but now for no reason I can't read boost. File attached if you need to see it.
    I've resorted to throwing various other tunes into spare ecms I have and powering them up in my personal vehicle. They are all doing the same thing. I've also changed out the MAP Sensor for another 2 bar and I get the same results. I changed the scaling on the map sensor ( C6301 ) back to a 1 bar scaler number and I can watch the car with Key On Engine Off read around 48 and as I increase boost toward 15 lbs I can see it go up towards 90. That tells me there is nothing wrong with the sensor or wiring. To me that only leaves the software.
    I'm desperate for any and all suggestions.
    Thanks for your time.
    Randy
    Read Stroker Tune_0000.ctz
    Randy, post your log files.
    Which kPa pids are you logging...?
    Sep 2006
    SAE Like the COS Upgrade says. But I did try everything that was related to MAP and still nothing.
    I've done a lot of these Joe. First time I've ever seen this.
    Try doing a full flash of your current tune file.
    Sep 2006
    I've done that a dozen times and I get the same result.
    Try logging these pids, let see what the PCM is doing:
    - SAE.MAP
    - GM.MAP
    - GM.MAP2
    - GM.MAP3
    - GM.MAP4
    - GM.MANVAC
    - GM.MAPBOOST_DMA
    - GM.MAPU
    - GM.MAPV
    - SAE.BARO
    - GM.BARO
    - GM.BOOST
    - GM.BOOST_DMA
    ( some of those have units "Volts" )
    Randy, I don't remember on the LS1 PCM but is there another PID related to MAP? Something like GM.MAP and not an SAE PID? (Edit, Joe just posted some MAP alternative PID's to try)
    We did have to make some changes to the SAE.MAP PID recently as the set up of that PID was changed by GM. It shouldn't have affected anything but there might be something funny going on.
    Sep 2006
    I just finished loading a laptop that has never had efi live on it before. V7.5.7 ( Build 309) I'm going to do a full flash of that vette file I did over a year ago. I'll pull it off my tuning laptop without opening it and copy to the new laptop and then do a full flash and see what happens.
    I'll also log all the pid Joe suggested even though I have tried a few of them already. I want to be very thouough so we don't miss anything. I've been beating my head against the wall for 2 full days before I asked for help.
    Thank you. Give me 20 minutes.
    Sep 2006
    Guys,
    Same results. I'm totally lost. The new computer had nothing on it like cax files or anything.
    I was only able to log the additional pid baro. All the others were grayed out.
    Baro was showing 99 at Key On Engine Off.
    Sep 2006
    I'm going to delete the EFI Live from the new computer. What Version of the software should I download to get in before you made the change to the SAE.MAP Pid? If it works with the older version then we will have our answer.
  1. 105 kpa in boost ve table (cos3)
    By LS1Nova in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: April 18th, 2010, 09:11 AM
  2. COS3 fueling issue under boost
    By joeygc5 in forum Custom Operating Systems
    Last Post: December 28th, 2009, 06:07 PM
  3. Boost leak MAF Reading
    By lownslo in forum Gen III V8 Specific
    Last Post: October 16th, 2009, 01:40 PM
  4. cant upgrade to COS3
    By charcold-bowtie in forum Custom Operating Systems
    Last Post: August 24th, 2008, 05:04 AM
  5. V1 TO V2 UPGRADE, Says I need the latest software???
    By nitrorocket in forum FlashScan V2
    Last Post: May 27th, 2008, 02:59 AM
