Results 1 to 2 of 2
Thread: Engine Reduced Power Help!
    Junior Member TorqueMonster007's Avatar
    Aug 2013
    Exclamation Engine Reduced Power Help!
    Just Cal flashed my 2016 with a tune file i had been building and also installed a K&N intake that was off of my 14' i traded for this one. All things the same basically between my 14' and new 16' (5.3/6l80e) and other than the operating systems are different i had absolutley no problems with the '14. After the flash of my new 16' (built file from scratch and just based some parameters off of my 14') as soon as you crank it it displays Engine Power Reduced on the info screen yet there is no CEL even after driving and it is not actually in limp mode. Runs and drives like normal. What could this be? Not sure if it's in the TCM or ECM, why i posted in both areas of the forum.
    2017 Sierra Denali Ultimate, 4x4, White Frost, 6.2/8speed, Leveled, 33x12.50x22 Trail Grapplers
    Stock for now
    Needs some T87A support love
    Sep 2007
    I had the same problem after a tune. Reduce the speed limiter top speed to about 240MPH and it goes away. Something in the program doesn't like the max speed even though you can put it in, and it gives that fault. I don't know where the conflict is, but this will fix it.
  1. Engine Reduced Power Help!
    By TorqueMonster007 in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: December 16th, 2016, 04:30 PM
  2. Reduced Engine Power help please
    By JUSTASBC in forum Petrol / Gas
    Last Post: August 25th, 2011, 11:55 PM
  3. Reduced engine Power
    By Webbs in forum Gen III V8 Specific
    Last Post: February 3rd, 2011, 08:18 AM
  4. P1514 Reduced Engine Power.
    By Mort in forum Gen III V8 Specific
    Last Post: April 2nd, 2009, 11:51 AM
  5. Reduced engine power
    By redlinepd in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: July 7th, 2007, 07:30 PM
