I sse table B5203 has several cells set to 5000 rpm (or lower).
When it refuses to spin higher than 5K rpm, does it throw any DTC's...?
What g/s airflow are you seeing (post some logs)...?
If you're exceeding 512 g/s then you will have to scale...
as an experiment try either of these:
- scale by 0.5 on MAF and VE/VVE, and by 2.0 on Stoich AFR B3671,
- scale by 0.5 on MAF and VE/VVE and IFR (I don't remember if B1210 needs editing, I'm just going blank...),
( and you may/will have to shift any table that references mass or mass/time )
