Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 71
Thread: Known Issues With Current Public Release
    Quote Originally Posted by Snipesy View Post
    Also would you be willing to add some PIDs if I threw them your way? (so I can bbx log them)
    I can add generic and enhanced PIDs but not DMA PIDs. So let me know whcih PIDs and I'll see if I can get them added.
    i attempted to do some logging today with the v8 scanner with the AEM on an E40 ecu.
    Whenever i attempted to click on the data screen, it would give me a AV error @ address 00965008. read address 00000028.
    Once that came up u clicked ok, then it would come back to infinity. so had to kill program.
    Also got the same error when trying to test a ben pid. except it only came up once. so i could get out of it
    Can you provide a detailed sequence of steps that will reproduce the problem? I tried doing what you explained in the post but I can't get it to fail.
    Dec 2015
    I sent a PM your way with the infos.
    I would connect with some pids and start recording. if i clicked on data screen i got the error. if i tried to test a calculated pid. i got the error. Joecar noticed the same thing and mentioned it in a post in the v8 calculated pids thread.
    Tre-Cool is referring to this: V8-Scan-Calculated-Pids~post#29
    Lifetime Member izaks's Avatar
    Aug 2003
    Setting D9602 to ENABLED, disables SPORT SHIFT mode when trans lever is moved to the SPORT position. If you then go into manual mode, it is locked in this mode, even if trans lever is moved back to auto. You have to shift out of drive and then back in to drive to disable manual mode and revert to normal drive mode. Tested on 2011 and 2012 VE.
    Was trying to find what prevents the trans shifting into 6th over +/- 240 when I saw D9602 and tried it to see what it does.
    2011 VE SSV 419 + CAM + Whipple 2.9FF SC + PPV front struts + Bilstein rear shocks + 6L90E with single piece carbon fiber prop
    Did some BBX logging on the E98, is there an update to the sae.map definition still to be done like the v7 software? or will it always max out at 255kpa? (built-in limitation) OR should i be logging something else?
    Just posted a fix for the MAP PID scaling issue. See first post for links.
    Downloading now. i'll give it a test shortly. Will also test the AEM wideband calculated pids
  9. #19
    Well, the BBX now logs over 255kpa, but now the v7.5 pass-through logger doesn't. lol
    Also noticed that when you do a compare with tunes, you can no longer double click on the item and get taken to the table etc.
  10. #20
    Can you post both logs, the one from bbx and the one from v7 pass-thru?
  1. Known issues with the October 2015 Public Pre-Release
    Last Post: November 14th, 2015, 10:09 PM
  2. Known issues with the September 2015 Public Pre-Release
    Last Post: September 11th, 2015, 10:46 AM
  3. Known issues with June 02, 2015 Public Release
    Last Post: July 8th, 2015, 05:07 PM
  4. Known issues with May 01, 2015 Public Release
    Last Post: June 2nd, 2015, 10:46 AM
  5. Known issues with April 13, 2015 Public Release
    Last Post: April 30th, 2015, 08:33 AM
