Page 5 of 8 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 71
Thread: Known Issues With Current Public Release
  1. #41
    Nov 2007
    When using CAX files, there is an option to allow definitions to overlap other CAX files, can this be extended to allow overlaps with EFILive definitions too?
    I think in some cases there are EFIlive definitions that are hidden or not editable. I understand locking it down to prevent inadvertent changes due to mis-configured CAX files however some users may need a bit more flexibility and by checking the box to allow overlaps we take on board the responsibility.
  2. #42
    Dec 2015
    Quote Originally Posted by kangsta View Post
    You could rename the .calz if its pressing.
  3. #43
    Sounds like it needs to be added as a PRO TUNER option.
    Chuck CoW
  4. #44
    Default AutoCal config files....
    Hey Paul.... With your help I polished up most of my AutoCal config files to load the appropriate maps and pids
    so that when I load a customers autocal log file every map opens and the correct pids are all loaded.
    Not sure if I'm asking the right question or no or if someone else is noticing the same problems, but seemingly
    after the most recent updates, I now have to manually load individual maps for submitted log files and it was never like
    this before. Hopefully someone else noticed what I'm seeing and it's just not the early onset of Alzheimers.....
    Chuck CoW
  5. #45
    Made public from a private e-mail....
    Hey Paul.... I noticed that the V7 calibration summary now includes segments that are different.
    VERY NICE! I would also hope that you include it on the opening page when you
    load a cal or alt cal for comparison so that changes are evident up front.
    It will be of big value especially for the LML duramax and other controllers where
    multiple segments could be different even when the OS is the same.
    The only thing I notice right now is that when I do the ctrl F12 to create the summary
    clicking on the items in the list does not bring you to the calibration the way it used to. (solved)
    What I suggested a year or so ago seems more appropriate right now.....so I repeat.
    I'm very thankful for the tune tool auto identifying alternate segments that are not identical. EXTREMELY HELPFUL.
    Maybe it could be a PRO TUNER option as well, but I would absolutely LOVE IT if (optionally) efilive could display the
    memory address(s) of the differences in each segment even if the tune tool or efi live does not display them.
    Now-a-days, there are too many occasions with all the different tuning tools out there where things are different and
    we can't see it.... It's a big problem for me. I'm quite sure there are a few of us out there that a feature like this would
    be EXTREMELY helpful for and its a feature that I would greatly appreciate.
    Hopefully there are others reading this that will recognize the value of a feature like this.
    Thanks for listening.
    Chuck CoW
  6. #46
    Feb 2016
    Not sure if I missed this someplace but when comparing files, it now shows the checksums are different between 2 compared files which I've not seen before. Also getting an Access violation error when trying to update one file with the compared file.
Name:	Error Updating Compared Files.PNG
  7. #47
    Quote Originally Posted by Chuck CoW View Post
    Maybe it could be a PRO TUNER option as well, but I would absolutely LOVE IT if (optionally) efilive could display the memory address(s) of the differences in each segment even if the tune tool or efi live does not display them.
    This is not possible, if the calibration is not defined in the tune tool then it cannot detect or display the 'unknown' differences.
  8. #48
    When I bring up the Speedo calculator, I get this pop up:
    EFILive Tune - Digital tools for onboard vehicle electronics
    Cannot create file "C:\Program Files (x86)\EFILive\V7.5\Configuration\cal_adjust.txt". Access is denied.
    OK
  9. #49
    Jun 2011
    Quote Originally Posted by Bdirtymax View Post
    I have the same problem
    What's the fix?
  10. #50
    The problem is the software is attempting to update the new segment/checksum items as if they were calibrations. That will be fixed in the next update. For now the workaround is to not have those segment/checksum items selected when you click on the [Update] button.
  1. Known issues with the October 2015 Public Pre-Release
    Last Post: November 14th, 2015, 10:09 PM
  2. Known issues with the September 2015 Public Pre-Release
    Last Post: September 11th, 2015, 10:46 AM
  3. Known issues with June 02, 2015 Public Release
    Last Post: July 8th, 2015, 05:07 PM
  4. Known issues with May 01, 2015 Public Release
    Last Post: June 2nd, 2015, 10:46 AM
  5. Known issues with April 13, 2015 Public Release
    Last Post: April 30th, 2015, 08:33 AM
