Results 11 to 20 of 32
Thread: V8 Scan - Calculated Pids
    Paul, also see post #139 in this thread: AEM-X-Series-OBDII-Wideband-UEGO-AFR-Sensor-Controller-Gauge
    Sep 2003
    I don't know if this is what you are trying to accomplish, but I just built this in V8.
    If not totally disregard.
Name:	EFILive Calc PID.jpg
    Quote Originally Posted by Ninety8C5 View Post
    Yes, it is what I want (see mine attached), but I wanted to avoid using an if-then/if-else, I wanted Paul to include a builtin iff() function or operator
    (hmmm, operator would be nicer than a function)
Name:	Function Editor~000013.png
    Can we get an official break down or explanation on creating calculated pids for V8 or let me know if your happy with my explanation?
    I've created a few Ben's tonight so i can start playing with the AEM CAN Wideband so thought i'd let everyone else know what i did.
    1) Just like adding calculated pids for V7.5, get your self a good text editor. I recommend Notepad++
    2) Browse to your My Documents\EFILive\V8\Config folder and open up the UserCalculatedPids.ini file
    3) Copy in the sample data below
    EFi Guys?
    You don't need to (nor should you) be editing that text file directly. You should use the built in calc PID editor for V8.
    [F2: Scan]->[Config]:Calculate PIDs (hotkey Ctrl_K)
    Paul, how do you comment (as in commenting out)...?
    It's Pascal/Algol-like:
Name:	Function Editor~000015.png
    So did what i have for a single wideband be all i need to have for a functioning BEN factor to populate a map?
    Until i connect to an ecu, i can't tell if it's actually going to populate a map. Seems you need to manually type in the data pid. How come we can't just select a pid like we can for the row/column tables?
    The language is Lua, so whatever is available in that language is what you can use. I'm not able to modify the Lua language - sorry :(
    https://www.lua.org/manual/5.2/#index
    You could try this: http://hisham.hm/2011/05/04/luas-and...nary-operator/ (although there's issues with nil values).
    I think it would look something like this:
    Code:
    return pid("EQIVRATIO") * ((pid("WO2LAM1")>pid("WO2LAM2")) and pid("WO2LAM1") or pid("WO2LAM2"))
    Or you could just write a function to do it, like this:
    Code:
    function iff(cond, a, b)
      if cond then
        return a
      else
        return b
      end
    end
    return pid("EQIVRATIO") * iff(pid("WO2LAM1")>pid("WO2LAM2"),pid("WO2LAM1"),pid("WO2LAM2"))
  9. #19
    Code:
    Code:
      if cond then
        return a
      else
        return b
      end
    end
    Thanks Paul...
    that's what programming is about, working with what is available;
    I ended up defining my own, the .ini looks like this now:
    [Groups]
    FUNCTION=Function definitions
    WO2SER=Wide Band O2 Sensors (Serial-Comms)
    WO2CAN=Wide Band O2 Sensors (CAN-bus)
    [FUNCTION]
    IFF=IFF,factor,0
    [FUNCTION.IFF]
    0=|-- FUNCTION.IFF
    1=|function iff(x,y,z)
    2=|if (x) then return y else return z end
    3=|end
    [WO2SER]
    WO2BEN="Base Efficiency Numerator (Serial-Comms)(Dynamically-Leanest)",factor,3
    [WO2SER.WO2BEN]
    0=|-- WO2SER.WO2BEN
    1=|return iff(pid("WO2LAM1")>pid("WO2LAM2"),pid("WO2LAM1"),p id("WO2LAM2"))*pid("EQIVRATIO")
    [WO2CAN]
    WO2BEN="Base Efficiency Numerator (CAN-bus)(Dynamically-Leanest)",factor,3
    [WO2CAN.WO2BEN]
    0=|-- WO2CAN.WO2BEN
    1=|return iff(pid("WO2S11")>pid("WO2S21"),pid("WO2S11"),pid( "WO2S21"))/pid("EQ_RAT")
  10. #20
    It seems like a pretty arbitrary and strange pair of tokens to use for block comments but it makes including/excluding blocks of code much easier:
    --[[ I want to exclude the next two lines
    a = b+c
    d = e+f
    ---[[ I want to include the next two lines
    a = b+c
    d = e+f
    Notice that by just adding another minus sign to the --[[ start comment token, it is no longer a valid start comment block, it is just a single line comment, so the two lines of code are now included again.
    The end comment token is also ignored because it is now just a single line comment.
  1. Calculated pids
    By x MadMAX DIESEL in forum Black Box Logging
    Last Post: June 22nd, 2018, 09:26 AM
  2. Calculated PIDS?
    By beav in forum Diesel
    Last Post: December 3rd, 2013, 04:19 AM
  3. Calculated pids not displayed on V2
    By ttls1 in forum Black Box Logging
    Last Post: October 7th, 2013, 08:47 PM
