Results 21 to 30 of 32
Thread: V8 Scan - Calculated Pids
  1. #21
    Thanks Paul...
    that's what programming is about, working with what is available;
    I ended up defining my own, the .ini looks like this now:
    I have not tried this, but you should be able to create a group/pid that contains multiple functions. I.e. say a group called "Global" and a PID called "Functions" and then define multiple functions in that Global.Functions "pid definition". Then you could call any of those functions from any calculated PID function.
  2. #22
    It seems like a pretty arbitrary and strange pair of tokens to use for block comments but it makes including/excluding blocks of code much easier:
    --[[ I want to exclude the next two lines
    a = b+c
    d = e+f
    ---[[ I want to include the next two lines
    a = b+c
    d = e+f
    Notice that by just adding another minus sign to the --[[ start comment token, it is no longer a valid start comment block, it is just a single line comment, so the two lines of code are now included again.
    The end comment token is also ignored because it is now just a single line comment.
    Paul, thanks.
  3. #23
    Paul,
    I want to draw your attention to this:
Name:	EFILive Scan Tool~000016.png
    and also to this (from post #7 above):
  4. #24
    Also, how do you log from two AEM 03-0334 units...?
  5. #25
    The V8 calc pid editor won't let me spell out Global, it stops after 4 characters... I had to dive into the ini file with Notepad++.
Name:	EFILive Scan Tool~000017.png
  6. #26
    Ahh yes, I did that to try and keep the total Group.PID name length to a reasonable size for black box logging.
    It should not be a problem for calculated PIDs, because calc PIDs are not logged/evaluated during black box logging.
    I may look at allowing those group names for calculated PIDs to be longer than 4 characters.
  7. #27
    Right now you can't. It is limited to only 1
    I'm not sure if/when EFILive will support dual AEMs.
  8. #28
    We have been using dual widebands, I tune to the leanest bank dynamically (using iff() in the BEN pid to select the leanest wideband lambda)...
    and since the AEM 03-0334 will have a high sample rate, dual wideband ability (ability to tune to leanest bank) would be a good feature to have.
  9. #29
    Paul,
    I also see an AV:
Name:	EFILive Scan Tool~000018.png
  10. #30
    Jul 2016
    Getting multi-channel lambda working with EFILive would be tricky. Somehow, both lambda channels would need to be reported by one gauge. So, one gauge would need to listen to the other, and, parrot its data. I guess I could rig up a test version that reports PIDs 0x24 and 0x25 from a single controller.
  1. Calculated pids
    By x MadMAX DIESEL in forum Black Box Logging
    Last Post: June 22nd, 2018, 09:26 AM
  2. Calculated PIDS?
    By beav in forum Diesel
    Last Post: December 3rd, 2013, 04:19 AM
  3. Calculated pids not displayed on V2
    By ttls1 in forum Black Box Logging
    Last Post: October 7th, 2013, 08:47 PM
